) L8 }' v B, P% z, S1 |
中地震地震网台报:发震时刻:2021-03-29 07:01:46纬度:43.70°经度:-28.72°深度:10千米震级:5.7参考位置:中大西洋海岭北部。 . r8 U( _( T6 |$ t9 `) p) A: Z; _
2021-03-27_23时CT监测到欧洲海底中强震的磁单极子G脉冲(图1)的地震发生了,震源确实在西半球欧洲附近海域,云南个旧的东方线上,因为北京时间23时,G脉冲出现时太阳在欧洲上空,所以预测地震震源在欧洲海底,注意:本次地震发生时月球正经过欧洲上空,显然与目前35万公里近月点的月球万有引力固体潮汐力作用引爆了地震,是压倒骆驼的最后一根稻草。显然地震界的余震说法是站不住脚的,就像压力锅如果撤销热源,就不会爆炸一样,没有天体固体潮汐力是不会发生地震的。研究发现以往地震学界很多理论是错误的,板块形成与挤压的动力太阳天体引力,包括气象动力。
+ b' @0 C2 L. T9 g. q. @4 X4 _ The earthquake time: 2021-03-29 07:01:46 latitude: 43.70 ° longitude: - 28.72 ° depth: 10km magnitude: 5.7 reference location: North of the mid Atlantic ridge. % U7 [. E$ g3 \+ s5 U# h
2021-03-27_ At 23:00, CT detected the occurrence of an earthquake with magnetic monopole g pulse (Fig. 1) of a moderate strong earthquake on the European seafloor. The earthquake source was indeed on the eastern line of Gejiu, Yunnan Province, near Europe in the Western Hemisphere. Because the sun was over Europe when the G pulse appeared at 23:00 Beijing time, it was predicted that the earthquake source was on the European seafloor. Note: the moon was passing over Europe when the earthquake occurred, which is obviously different from the current 3:00 The earth quake was triggered by the tidal force of the gravitational solid of the moon, which was 50000 km near the lunar point. It was the last straw to overwhelm the camel. Obviously, the aftershock theory in the earthquake field is untenable, just like if the heat source of the pressure cooker is removed, it will not explode. There will be no earthquake without the tidal force of celestial bodies. It is found that many theories of Seismology in the past are wrong, such as the motive force of plate formation and compression, solar celestial gravity, including meteorological motive force.
3 F9 V* }& v+ H2 X
. i# ~3 o# o- K9 u) G3 o % T: N P1 W" D; m1 L
% ~, c' {* t' o
9 J$ l; B& I% \6 d
8 g# p! K9 S- R4 @. v9 q" g
' N7 o+ ]3 c; d* O
( x2 [0 V3 a$ s$ o' G t2 a. T! S
1 \) ~# ]; l: v" V# E% v2 d: _
) r/ ]% G: U* F% h! \, ^) U9 s
7 d, A; ^! l; O2 X5 U6 R
, J$ X2 F* e8 s. b! x |
