【浮游生物类仪器】德国HYDRO-BIOS公司 浮游动物计数框
德国HYDRO-BIOS公司——浮游动物计数框4 Q) |  a$ P7 |# l) N$ Z
Counting Chamber for zooplankton
. O' P- V7 n+ ?1 T9 S1 j' G+ L& l) ?7 ~6 B% ?
; u7 W) m. l2 c) }/ `6 W& K
; u$ A8 i8 S, W4 v
; D3 x, c7 p0 F( h  |. x/ N
浮游动物计数框用于在体式显微镜底下对浮游动物进行观察计数。浮游动物计数框由树脂材料制成,底面抛光,具有较好的透明度,可将其放置到常规显微镜上对浮游动物进行观察。/ b% B/ E9 {: e/ o3 b. l& J+ I0 G* m
- ]' L/ Q; H9 a0 W% y" R* U" C
9 K) I9 ?# O- J; R; b
5 x. H" X/ C4 L# h3 t
! X) @* }4 D# Q5 u4 r
浮游动物计数框订购指南:' s: L7 g7 v! R( |  D
浮游动物计数框由树脂材料制成,底面抛光,具有很好的透明度! o+ P+ c* a) F, ~% W, B2 x! g+ W: f
6 G6 V" t: @2 X- C+ _# U$ l
& P1 b0 y4 g/ k' O4 |% Z" u        435 010     浮游动物计数框尺寸40×70mm,容纳样品量约9ml
0 z/ Q& d' P" z' y5 O# `
+ @( n4 M4 U; R. g
0 r& d4 k4 A5 }9 G3 w
        435 011      浮游动物计数框尺寸80×100mm,容纳样品量约22ml4 \' f) ~  J" S
        435 011A   浮游动物计数框尺寸80×100mm,容纳样品量约6×5.4ml
4 y. s, ]8 Q7 b( y        435 011B   浮游动物计数框尺寸80×100mm,容纳样品量约12×2.4ml
$ b# h7 J4 S) ^3 m' |  [        435 011C   浮游动物计数框尺寸80×100mm,容纳样品量约30×0.8ml
9 D& O: p- ~$ o; V6 z/ b# j
* S! Y6 Q5 i  E7 e; U
* s2 {5 g' w- U: H6 `1 W" r. q, ~; ]/ g
        435 012    浮游动物计数框尺寸80×140mm,容纳样品量约70ml
/ b' `- V5 T1 X9 z0 O( W, O( e) \$ _' z: f: I
3 l) y6 d& s. V- q% G! _% c代表文献:  Y# i- W% ~- j! A
1.Manfred Rolke and Jürgen Lenz,1984.Size structure analysis of zooplankton
% H, ?3 y6 @. z& G* O6 Rsamples by means of an automated image analyzing system.Journal of Plankton Research.6(4): 637-645.
, M4 @' o0 }0 W6 v7 k2.Austin B.M. Egborge and Prekeyi Tawari,1987.The rotifers of Warri River, Nigeria.Journal of Plankton Research.9(1):1-13.. X* ~' {/ \# x3 D& u- n
3.J.W. Rijstenbil,1987.Phytoplankton composition of stagnant and tidal ecosystems in relation to salinity, nutrients, light and turbulence.Netherlands Journal of Sea Research.21(2):113–123.
+ c2 C7 W7 p: t4.S. Wagener, C. F. Bardele, N. Pfennig,1990.Functional integration of Methanobacterium formicicum into the anaerobic ciliate Trimyema compressum.Archives of Microbiology.153(5):496-501.; ]6 H6 y/ X- e
5.S. Holler, N. Pfennig,1991.Fermentation products of the anaerobic ciliate Trimyema compressum in monoxenic cultures.Archives of Microbiology.156(4):327-334 .
1 y$ M# R3 k0 h+ Q7 m$ j, _6.J. W. Rijstenbil, C. Bakker, R. H. Jackson, A. G. A. Merks, P. R. M. de Visscher,1993.Spatial and temporal variation in community composition and photosynthetic characteristics of phytoplankton in the upper Westerschelde estuary (Belgium, SW Netherlands).Hydrobiologia.269-270(1):263-273.! K8 G1 W+ q, q+ T4 U
7.Bettina Meyer-Harms, Falk Pollehne,1998.ALLOXANTHIN IN DINOPHYSIS NORVEGICA (DINOPHYSIALES, DINOPHYCEAE) FROM THE BALTIC SEA.Journal of Phycology.34(2):280–285.) }" g, n; l. \5 }. a
8.Catalina Castell Perez, Suzanne Roy, Maurice Levasseur, Donald M. Anderson,1998.CONTROL OF GERMINATION OF ALEXANDRIUM TAMARENSE (DINOPHYCEAE) CYSTS FROM THE LOWER ST. LAWRENCE ESTUARY (CANADA).Journal of Phycology.34(2):242–249.
6 w+ b: y3 E/ Q9 w" x9.Teresa Cruz and Jorge Araújo,1999.Reproductive Patterns of Pollicipes pollicipes (Cirripedia: Scalpellomorpha) on the Southwestern Coast of Portugal.Journal of Crustacean Biology.19(2):260-267.' j  ?2 ?" R# o" c1 Z! x3 g3 Y
10.Michael Hust, Wolfgang E Krumbein, Erhard Rhiel,1999.An immunochemical in situ approach to detect adaptation processes in the photosynthetic apparatus of diatoms of the Wadden Sea sediment surface layers.Journal of Microbiological Methods.38(1–2):69–80.0 o( A: @8 U# s! H5 {1 |* B
11.Christine Dupuy, Solange Le Gall, Hans J. Hartmann, Martine Bréret,1999.Retention of ciliates and flagellates by the oyster Crassostrea gigas in French Atlantic coastal ponds: protists as a trophic link between bacterioplankton and benthic suspension-feeders.Marine Ecology Progress Series.177:165-175.# u3 f: K  s! u. Y
12.A. Tewari, H.V. Joshi, R.H. Trivedi, V.G. Sravankumar, C. Raghunathan, Y. Khambhaty, O.S. Kotiwar, S.K. Mandal,2001.The Effect of Ship Scrapping Industry and its Associated Wastes on the Biomass Production and Biodiversity of Biota in in situ Condition at Alang.Marine Pollution Bulletin.42(6):461–468./ z- H0 h9 L8 F, h3 Y/ o
13.Hera Karayanni, Urania Christaki, France Van Wambeke, Andrew P. Dalby,2004.Evaluation of double formalin—Lugol's fixation in assessing number and biomass of ciliates: an example of estimations at mesoscale in NE Atlantic.Journal of Microbiological Methods.56(3):349–358.. j! W! ]: T* v; u4 c
14.EI Ohimain, TOT Imoobe & MO Benka-Coker,2005.The impact of dredging on macrobenthic invertebrates in a tributary of the Warri River, Niger delta.African Journal of Aquatic Science.30(1):49-53.
/ A: H2 M" s, W8 s2 ~4 ]15.Laurent Seuront, Dorothée Vincent, James G. Mitchell,2006.Biologically induced modification of seawater viscosity in the Eastern English Channel during a Phaeocystis globosa spring bloom.Journal of Marine Systems.61(3–4):118–133.# @: J4 i- C( U; [, ~# ^) y- O7 e
16.Wim A.M. Hijnen, Yolanda J. Dullemont, Jack F. Schijven, Anke J. Hanzens-Brouwer, Martine Rosielle, Gertjan Medema,2007.Removal and fate of Cryptosporidium parvum, Clostridium perfringens and small-sized centric diatoms (Stephanodiscus hantzschii) in slow sand filters.Water Research.41(10):2151–2162.
( U' S! i$ e! l0 o: a% [17.Géraldine Sarthou, Dorothée Vincent, Urania Christaki, Ingrid Obernosterer, Klaas R. Timmermans, Corina P.D. Brussaard,2008.The fate of biogenic iron during a phytoplankton bloom induced by natural fertilisation: Impact of copepod grazing.Deep Sea Research Part II: Topical Studies in Oceanography.55(5–7):734–751.) k7 d* `( v9 s/ J/ s# `- q
18.Damir Viličić, Tamara Djakovac, Zrinka Burić, Sunčica Bosak,2009.Composition and annual cycle of phytoplankton assemblages in the northeastern Adriatic Sea.Botanica Marina.52(4):291–305.9 l$ t# Y% n% M3 d% d8 c: w
19.Fedekar F. Madkour, Mohsen M. El-Sherbiny and Maher A. Aamer,2010.Phytoplankton population along certain Egyptian coastal regions of the Red Sea.Egypt J. Aquat. Biol. & Fish..14(2):95-109.) F. K5 q+ {- t
20.Mianrun Chena, Bingzhang Chena, Paul Harrisonb, Hongbin Liu,2011.Dynamics of mesozooplankton assemblages in subtropical coastal waters of Hong Kong: A comparative study between a eutrophic estuarine and a mesotrophic coastal site.Continental Shelf Research.31(10):1075–1086.' h: z0 G7 _# Y/ t) E' q& @
21.Germán A. Kopprio, Gerhard Kattner, Martin Graeve, R. Hugo Freije, Rubén J. Lara,2012.Exceptional lipid storage mode of the copepod Boeckella poopoensis in a pampean salt lake, Argentina.Aquatic Biology.15:275-281.5 E, g" q* N" U
22.Dongyan Liu, Yajun Shi, Baoping Di, Qianli Sun, Yujue Wang, Zhijun Dong, Hongbing Shao,2012.The impact of different pollution sources on modern dinoflagellate cysts in Sishili Bay, Yellow Sea, China.Marine Micropaleontology.84–85:1–13.
+ f8 x& h. v! @. Q, ~8 n! V5 Q23.Daniel Remias, Andreas Holzinger, Siegfried Aigner, Cornelius Lütz,2012.Ecophysiology and ultrastructure of Ancylonema nordenskiöldii (Zygnematales, Streptophyta), causing brown ice on glaciers in Svalbard (high arctic).Polar Biology.35(6):899-908./ X$ K/ O* t4 E# y
24.F.S. Tahami, A.G. Mazlan, H. Negarestan, Sh. Najafpour, W.W.M. Lotfi and G.D. Najafpour,2012.Phytoplankton Combination in the Southern Part of Caspian Sea.World Applied Sciences Journal.16(1): 99-105.) X) `5 @/ J4 h) v
25.Amir Abbas Bazyar Lakeh, Werner Kloas Rainer Jung, Ra’anan Ariav, Klaus Knopf,2013.Low frequency ultrasound and UV-C for elimination of pathogens in recirculating aquaculture systems.Ultrasonics Sonochemistry.20(5):1211–1216.
5 W6 a. Y* o* b# Y, B0 x% k) q1 {
, O1 M2 w  }& N; K& ^* b3 H1 H, }" m' ~& }6 S% O8 {% v# R0 J0 q
更多关键字: 浮游动物计数框,浮游生物计数框,浮游生物观察组件: }8 H# p1 k+ |" j
* ?- p. ~/ z: u- c* g/ j1 ^( A' X
9 y7 S% p* i9 ]* P5 D
' Z) @9 b3 M7 H6 P3 a
<strong>
oceaner
活跃在2026-1-19
