测速范围:0.04~10.Om/s
6 K. v9 W* v# P# X6 c% v: D工作水深:0.2~40m 6 f" j& M1 ~/ Y+ j5 b* [( n/ D
信 号 数:20转1信号 9 b. @4 Z7 v; P' P6 i, S; M
特 点:量程大,高中低速兼顾. 1 F& N7 T; s0 @
用 途:可用于江河等高、中、低流速及电站、溢洪道的高流速测量.
$ _& z! w+ n6 K i全套仪器:流速仪主机需配CG20型测杆、流速仪和信号线等使用.1 m8 G% e' Y( z; v) p' U e
Measuring range: 0.04~10.Om/s
5 p1 _) D6 `% t& f8 pWater depth: 0.2~40m
2 }1 P$ @6 r( {9 e: W+ v/ ?5 @( qFeatures: large measurements range.
2 e p% e9 L7 f: T0 hApplication: It is widely used for measurements of the flow velocity and high flow velocity in rivers、lakes、 reservoirs, pressure conduits and spillway of hydropower stations. ( V# J7 v% H- W" r. N7 Y
Notes: The Current Meter needs CG20 wading rod、 monitor、 wire for use. , ]4 s/ K) Z9 ]7 G0 |4 _, d% C
转载自:化工仪器网 |
