技术参数! c( n% \) Q/ s5 A' E
| DZB-718L: L5 q" H, |0 y2 W3 C8 |
pH/pX模块
% c$ |8 s; ~* _+ ]& k | 电导模块3 v4 U8 G. g( J: Q
| 溶解氧模块. w5 a! b3 U! }! i
仪器级别
0 h: Z( C+ w: x& M: n O) G | 0.001级
1 |4 M1 P @# _" c | 0.5级
4 i( Q# M) }' S# e4 T% _& N | ±0.30mg/L0 M' ]* d; I. @. M. B/ a1 x2 Z, l
测量参数- g3 ]# D9 K7 _+ `2 a# W
| pH/pX、电位、离子浓度、温度1 x$ y% `0 D; B7 v0 O/ A! T
| 电导率、电阻率、TDS、盐度值、温度
3 Q1 O& I; ~% L; b- J7 |- M/ B! Y | 溶解氧、溶解氧饱和度、温度6 k, ~+ \) s/ h5 z( l
测量范围
R; F* a6 H4 f0 e2 o8 G | pH/ pX# f* l8 ?( v) P' B0 j! @4 q
| (-2.000~20.000)pH/pX
! f& i- |! W% }, u. `( j4 C X. Y: j* H* y$ n1 t
6 ?( Z5 Q/ t1 ]! u& ^/ {2 G | — q& O& o( _+ O) P2 v
3 ?! h7 L% k% j- Y8 G4 y4 ? |
电位
; v9 Y% W p$ w) X | (-1999.99~1999.99)mV9 N9 Y1 F) e( E/ D7 d! x
& `: W2 W+ j* P# ~. L. o# k | —
$ L. F! L1 d" O4 z2 W | 7 ?$ [8 f3 ~2 U6 Z5 J5 x
离子浓度
1 o3 q0 O& t9 q$ J* F- P# l4 S | (0~19990),单位mol/L、mmol/L、g/L、mg/L、μg/L d& h4 O3 r" \7 I' ?
| ●% | c- z4 s3 s+ Q" }
| —; X: h9 J) H" {% o
| —1 r7 g# f+ i0 W) [1 G0 G
电导率% b; L7 S" K2 M% t4 J8 a
| 0.000μS/cm~3000mS/cm A( E7 K8 @# x0 r
| —; B u8 |) A# i6 j: N& j5 ]
5 s w! C! d' [% h | —
, Y8 |1 D& J! l* n. T; Z. N. M$ i |
电阻率
) | v( s+ c5 P: X+ H2 I' ]7 L | 5.00Ω.cm~100.0MΩ.cm# N+ M$ |1 H2 X! _8 j G
$ c3 d* i/ s8 v9 f3 B* k | ●
8 b5 _2 I) Q$ \( H0 n+ b | —; T% e: t! t1 x, R/ V5 W
TDS
L# f7 M4 S2 _ y | 0.000 mg/L~300g/L
# D- m$ C( G* t O# W" N. v | —
|( U9 X7 Y* ^3 M/ i* ] | ●7 j8 Y5 {7 s2 o! z0 l% O
| —3 g, P+ T( P# L& S
盐度
9 ~1 @2 A. N" Y. p: p' B8 I9 O& m | (0.00~8.00)%+ P# x3 h3 [. Z: u- z, ^5 K0 O! K
( w! e0 G1 B% A/ F5 [- j5 { | ●
# B$ I9 i. z1 {( E | —, C9 _- v. B; e5 Y5 _
溶解氧( r. e& i9 a, Q2 D3 I; ?
| (0.00~99.99)mg/L# ?/ e: b: D8 m
| —0 X8 B9 Y/ m" A- O9 u9 y* l- [0 A" p
| —0 o9 {, y' z2 ]1 r( h( _$ j
; F8 x: i, _8 g6 L* n, K+ M |
溶解氧饱和度
: K6 b; C) @3 Z7 r" J, G | (0.0~600.0)%
- u4 U/ z" G6 E) E: e | —; M; v7 Z" B J6 N
| —( h, {! s! k: x$ V4 J# Z
| ●9 s) v9 ?) C' |( B8 x1 v# v o, e) j) B
温度- g9 a) n( j& k. s0 U5 H6 \- }7 _
| (-5.0~130.0)℃
* E7 i/ Q* _" H# z | ●
) L- u6 K% |! I- \9 j | —* P5 B1 u; t! s/ D5 b5 N
| —- T2 j5 v5 i f+ E
分辨率
$ W; |, D4 r1 K. W2 y) J. i/ I+ h+ E | pH/pX
0 @4 a1 |; }" @ | 0.001 pH/pX;0.01 pH/pX. J( m* F7 S' @6 w7 g1 i
| ●1 d% V4 B: v$ |# [2 k0 r
| —: B5 p @& c- g0 _3 W9 v( C& e
| —: e! [5 K% A o5 n
电位$ K0 p/ [0 X9 X* J
| 0.01 mV,0.1mV' g' x* _2 L1 ~) F5 v
| ●; k1 k8 }% ~: o( h- K9 u
| —+ B( [3 B" G0 A+ m
| —4 D1 O7 _. U5 b+ W, ~
离子浓度
$ Z. G$ N, @! ^4 d( V" m | 五位有效数字
9 L8 P3 p7 v5 ^- G4 Z$ I(科学计数法表示)8 ?" A! @# ~! R E
: }- U2 }/ b. }5 E% z | —
3 n5 G/ l7 ~7 Y: @ | —+ L- J6 N9 ]. g, W- d+ u
电导率% |6 A2 _6 e# F9 u8 @5 @8 p' h1 h, ]
| 0.001μS/cm: O8 R2 N0 G6 x
| —& i% B( L, Y0 l
5 ?/ H3 ]4 s1 n) [ | —! f( W7 v" K/ Y4 x4 |6 r3 F& W
电阻率7 C) Q. K. E1 [; T# M& }
| 0.001Ω·cm( N9 o' R! f, M% y J& b7 B
+ m8 M. x* D5 P8 z+ @' j0 f$ O | ●
8 {2 ^6 I2 k/ x2 r; r | —" g# S1 U |7 v2 [2 R
TDS# g( F, |. ?. ?8 s+ t* Q# [
| 0.001mg/L, N/ S& g7 G. I5 ] z6 U
| —5 `( o3 _: U; z2 J4 S
| ●) ? y5 M$ w4 H; r
| —+ O& Q ^9 H" i) k( I% _: S$ o
盐度
1 M+ \0 G+ v2 s4 ?1 d5 c( X; L7 M | 0.01%
' \- A5 s/ o3 f2 z | —
6 K: S+ `. W7 {' f9 l G E* O2 h | ●
" p% V, g" g8 J$ [3 w( G/ w8 A | —9 a4 z5 h* Z5 Q3 _; A
溶解氧% n- S% L+ n) |' z7 v
| 0.01mg/L3 p) r* Q" F @0 @: K2 z( t
3 g9 s! \) [, X: G | —+ p2 ?! h8 K4 h* O$ k& w- H
: h$ Z+ I& J4 b9 y |
溶解氧饱和度
; ]1 }: u7 i2 }2 Q# _6 Y | 0.1%
, q# C0 P0 f* F* Y7 z+ ~ | —
8 a/ W- u O) N7 c6 H) i6 `" X$ a | —6 p" B8 H" |- R- x& m" m! M' A
1 \% B9 M* i3 }. \+ l- { |
温度: U4 y$ K1 l# i4 F1 ~ J: w$ g
| 0.1℃3 ^) Z( ?4 ~' x. f2 j# A& o' q# H
4 l) t" t6 {4 ~: U E, x2 n | —
$ P/ o' ~& H H6 R3 J+ U1 [ | —
9 a# `2 K7 b/ s ], C) N4 r% z |
基本误差; ]+ Z' O- _# d4 j! e5 {
| pH/ pX
- J( N$ _$ K) ], R" p9 j | ±0.002pH/pX
! K/ [9 O* v: g' j7 s2 ~ | ●8 y# ]8 n2 f9 Y% n+ X
/ e$ O( C. C: _( H! L | —4 |/ t3 Q4 h" u
电位! c2 S+ i+ i! A3 b: K) r5 K5 p
| ±0.1mV或±0.03%# @0 [# [4 A3 K* g1 z. _; k* s
+ X% G j7 C4 ?0 X3 l | —8 \) k2 D4 |4 m
" e; h, c$ U6 D5 q+ Y$ U |
离子浓度1 w2 E) G4 h: M7 ?4 e
| ±0.3%5 O1 W! \) X6 n: Q% `& l, j: w( \
| ●, {% n2 G& P" v& G+ g. B5 w
9 J; Q+ T7 A/ A- X2 C | —+ c; E; r7 x2 a$ E6 X7 i
电导率: D9 @: X' E& X$ k$ g& u
| ±0.5%(FS)' }' L, W1 b. Y) Y
$ N* j; p* g$ ?3 N# `2 w | ●7 m; P$ R8 P- @/ \
| —) v1 C" E( I ] P3 W0 _, |
电阻率2 x8 O, o! P" L% R4 f9 G. A
| ±0.5%(FS)# L2 }) v, j4 b# b( }
' c$ d2 n* `* n( \4 ]& o/ j | ●
! j+ I: i7 }9 [8 e | —
& W: z; [7 P2 U: y |
TDS
7 k4 \; ?. D- z% X( B% a- \; o | ±0.5%(FS)
' A5 N0 B K. V4 c | —
! R, U; x+ n# z# ] | ●. t5 g( r! B$ G+ f0 T9 D2 a
| —0 f+ C; p$ o- x5 S; K4 B, n" w/ b0 o. O
盐度; M2 t( j. |( K+ L$ N$ s
| ±0.1%
0 ]" L4 s) L. y6 v9 W+ x4 e | — w. R* {1 b5 z& K+ ?
5 R2 N: W* u0 S8 c | —6 b0 x0 _* p5 E; P
溶解氧: U8 O: {1 N6 A/ h; M$ j
| ±0.10mg/L1 u) a' p2 ^6 }+ \
6 F9 ~* `2 l* |2 a | —
' {. G" G I& Y& d7 w& B; _6 ~0 O | ●
8 |& J( f2 A- w5 _" K/ y+ F |
溶解氧饱和度
1 f }4 s/ F2 c | ±2.0%
# L: P8 \& m, |3 f | —
& E n, V* P0 E$ _3 C | —
3 z9 O; d( r" p# l" { | ●
; p! f. z' B3 O. s4 O/ n0 n8 z0 P |
温度. a; g) z6 Q' V' }, f. \
| ±0.1℃
! C6 N# K/ z. f3 e" j- D | ●! a# e C$ `/ O5 u& ~7 k0 }
9 b6 U! w9 \3 o( S1 ~ | ●
/ _. z9 ~% ]* E8 {" f6 o |
电源5 ^% Y0 i* d, R9 M3 `( U9 N' N2 F
| 可充电锂电池(DC 3.8V)
" E9 C, q3 i# }. {& q5 q% z7 s' J" W |
尺寸(mm),重量(kg)
# T; G, M! V0 z: s+ P | 201 mm×96 mm×55 mm;0.3kg0 O0 @% A: ]: k* O% d
标配电极
0 e2 u K: ?( S0 D) M* B | E-201-L型复合电极5 [* c* |0 g, U/ A, G; r& V
DJS-1-L型电导电极
, x6 I8 c, ?" o0 ^: d$ lDO-958-L型溶解氧电极1 @8 O7 h- S. t% L" k' W& t
标配电极配套测量范围
9 l8 ?$ z$ x) h9 d% C0 Z$ F7 D | (0.000~14.000)pH
% l$ ] A' @6 u) b' r! Q6 e2.000μS/cm~200mS/cm- J: y; t1 g0 u7 h5 o
(0.00~20.00)mg/L: ~ L) w# @& J- C4 l" I/ p" o
