转载:
. V* Z7 z0 @2 B6 d本文作者:波哥% h1 o2 b1 \9 Q3 u
联系邮箱:916490285@qq.com " S/ I$ P9 O4 {8 l$ C7 k
3 A- e2 Z% |* |
' B. {7 R0 k f4 G! K[C] 纯文本查看 复制代码 clc;clear;close all
ncdisp 'F:/RMatlab/data20211219/data46/air.mon.mean.nc';%查看气温数据中的变量
file_air='F:/RMatlab/data20211219/data46/air.mon.mean.nc';
lon=double(ncread(file_air,'lon'));% 直接双精度读取;
lat=double(ncread(file_air,'lat'));% 直接双精度读取;
T2_air=double(ncread(file_air,'air'));% 直接双精度读取;
T2_mean=nanmean(T2_air,3);% 对时间求平均
% land.nc
%找出陆地和海洋的经纬度,想画陆地上的气温,就把海洋上的气温设为nan,反之成立;
file_land='F:/RMatlab/data20211219/data46/land.nc';% 关键陆地文件;1代表陆地,0代表海洋;
ncdisp 'F:/RMatlab/data20211219/data46/land.nc'
land=double(ncread(file_land,'land'));
land=land+1;
land(land==2)=0;
T2=T2_mean.*land;
T2(T2==0)=nan;
[xx,yy]=meshgrid(lon,lat);xx=xx';yy=yy';
figure(1);
m_proj('Equidistant','long',[0,360],'lat',[-90,90]);
% m_proj('miller','lon',180,'lat',[-90 90])
m_contourf(xx,yy,T2,50,'linestyle','none')
% m_pcolor(xx,yy,T2)
% shading interp
% h=m_coast('patch',[0.8 0.8 0.8],'edgecolor','none');
hold on;
% m_gshhs_i('patch',[0.6 0.6 0.6],'edgecolor','k');
% m_coast('color',[0 0 0],'linewidth',1);
m_coast('patch',[1 .85 .7]);
m_grid('ytick',[-90:30:90],'xtick',[0:60:360],'tickdir','out','linest','none','fontname','Times','fontsize',12,'linewidth',1.5);
title('海洋气温','fontsize',12);
c=colorbar('eastoutside','ticklength',0);
caxis([-30,30]);
colormap(m_colmap('jet'));
ax = gca;
axpos = ax.Position;
c.Position(3) = 0.5*c.Position(3);
ax.Position = axpos;
cbarrow;
disp('!!OK!!'); 3 l0 z$ F' E5 j1 H* S1 R
, {/ R7 i6 ]2 ?% f5 g( \5 s8 o
! N, {8 @( i. c' g5 p' o7 Y* {, o
$ C- }$ z8 ?& u( Q! t. O: p, c" m$ j- x
7 K% f& e- t; e3 @, j
/ G0 r% O! o% N3 I% }: h4 D; t" ?" _1 X. v. i1 K g1 I7 U
; C( J9 {; i9 v3 @/ {
% land.nc
T2=T2_mean.*land;
T2(T2==0)=nan;
figure(1);
% shading interp
hold on;
% m_coast('patch',[1 .85 .7]);
caxis([-30,30]);
ax = gca;
cbarrow;
disp('!!OK!!');
% G |; w' q: Q1 N' E
6 b9 \" w) O4 c7 B3 [8 E
2 _4 k1 Z7 Z4 W. ^% L1 n& Q* N( C- r0 a7 S \1 X E
6 y% \" g, X1 p# l5 c
6 ?8 X+ L. a5 u* c6 M* d4 n
P$ z1 w3 I8 I8 z+ u' K; D[C] 纯文本查看 复制代码 clc;clear;close all
T2=land.*T2_mean;
T2(T2==0)=nan;
ncdisp 'F:/RMatlab/data20211219/data46/hgt.mon.mean.nc'% 查看位势高度数据中的变量
file_hgt='F:/RMatlab/data20211219/data46/hgt.mon.mean.nc';% 查看海温数据中的变量
hgt=double(ncread(file_hgt,'hgt'));
level=double(ncread(file_hgt,'level'));
hgt=squeeze(nanmean(hgt(:,:,3,:),4));%对时间求平均,并且取850hpa的位势高度场;
file_u='F:/RMatlab/data20211219/data46/uwnd.mon.mean.nc';
file_v='F:/RMatlab/data20211219/data46/vwnd.mon.mean.nc';
u=double(ncread(file_u,'uwnd'));
v=double(ncread(file_v,'vwnd'));
% ncdisp 'slp.mon.mean.nc';%'Sea Level Pressure'
file_slp='F:/RMatlab/data20211219/data46/slp.mon.mean.nc';
slp=double(ncread(file_slp,'slp'));
slp=nanmean(slp,3);
land=land+1;
land(land==2)=0;
slp=slp.*land;
slp(slp==0)=nan;
u=u.*land;
u(u==0)=nan;
v=v.*land;
v(v==0)=nan;
fig_pos = [0.2 0.02 0.53 0.8];
figure(1);
ax1 = axes;
set(ax1,'position',fig_pos);
% m_pcolor(xx,yy,T2);% 陆地气温
m_contourf(xx,yy,T2,100,'linestyle','none')
shading interp
colormap(ax1,'hsv');
ax1_h=colorbar(ax1,'Position',[.07 .1 .02 .55]);
set(get(ax1_h,'Title'),'string','气温','fontsize',12);
caxis([-50 30])% min(min(T2)) max(max(T2))
% m_coast('color',[0 0 0],'linewidth',0.2);
m_coast;
hold on
ax2 = axes;
set(ax2,'position',fig_pos);
m_contour(xx,yy,slp,50);% 陆地气温,'linestyle','none'
% m_pcolor(xx,yy,slp);% 陆地气温
% shading interp
colormap(ax2,'winter');
caxis([980 1022])% min(min(slp)) max(max(slp))
% m_coast;
ax2_h=colorbar(ax2,'Position',[.75 .15 .02 .6]);
set(get(ax2_h,'Title'),'string','slp','fontsize',12);
% saveas(gca,'两个colorbar3.png')
figure(2);
fig_pos = [0.09 0.15 0.53 0.75];
ax1 = axes;
m_pcolor(xx,yy,T2);% 陆地高程
shading interp
colormap(ax1,'jet');
caxis([-50 30])
% freezeColors
ax2 = axes;
% m_contourf(lon,lat,sst','linestyle','none','levelstep',.1);
pc = m_contourf(xx,yy,slp,10);% 海表温度
% set(pc,'linestyle','-');
colormap(ax2,'hsv');
cb1 = colorbar(ax1,'Position',[.65 .15 .02 .6]);
cb2 = colorbar(ax2,'Position',[.74 .15 .02 .6]);
- q( A+ W. R: a$ F1 V5 j
( X% p( A6 ^# I% t* T( o/ K5 R' o, }8 ?4 q2 B6 B; d2 p H
5 u/ j/ e% V, ]" o* ^' g( X* e/ G( o9 F& z. O$ h6 |, o
! \4 m$ c/ r4 @# f获取本文Matlab绘制一张图里多个Colorbar 数据的途径:; |# U7 |! s" @6 S
+ z; f( U- L1 F+ ^: Q7 f
