台风“灿都”强度路径及影响舟山降水成因分析
+ s; n; O4 h; `# k4 p: b( q1 c# Z1 r
; e8 u7 ^* [! |1 \: |! F  ]
/ b; c1 ~6 c  x/ z0 k7 [' o5 y
! Y9 {% b' U, n8 O( d8 A. l$ I9 n
( T# k) P1 u7 w3 A8 p% q$ ^& Y' e: x" B, e+ q
台风“灿都”强度路径及影响舟山降水成因分析1 N; I+ H2 P; z+ @0 y) l2 Z$ K  Y1 b
全文请用PC端下载 地址:
6 H7 Q4 e" K! `5 d+ {1 m7 V, s" ~' n9 S
http://www.hyyb.org.cn/Magazine/Show.aspx?ID=3459) _6 @8 r- b/ D! M& ^9 _
读书小笔记
- r6 c4 U6 F8 t/ }# X; ~5 p作者:徐逸雯 王倩 卢琪 孙轶6 q, L5 h7 R9 w% L- c3 D
单位:舟山市气象局, 浙江 舟山 316000/ C! P0 ?9 R8 Z9 ^' D
分类号:P444
- I( F, O# m8 o$ i7 {出版年·卷·期(页码):2023·40·第一期(91-100)! {" ?1 x7 s' _6 N& x; D& B1 J
摘要:基于欧洲中期天气预报中心的 ERA5 再分析数据、浙江省自动气象探测站数据等,对2021年14号台风“灿都”(Chanthu)的移动路径和强度变化进行分析,对路径和强度的预报偏差机理进行研究,初步探讨其影响舟山的降水成因。结果表明:台风“灿都”核心区范围小,外围环流较为广阔;路径偏差主要与副热带高压与大陆高压有关,副热带高压预报偏强,南支高压被低估;台风“灿都”在东海北部海域回旋时处于高压区的包围中,没有明显的引导气流;较高的海表面温度为超强台风和强台风的维持提供了热力条件;台风“灿都”在舟山的降水特征表现为小时雨强不强、持续时间长、累计降水量可观。定海西南侧出现强降水主要是受到山区地形影响以及水平方向风速差。
$ _! Y& a" k& D关键词:台风“灿都” 副热带高压 强降水 路径偏差 强度变化
$ S( r) n, ]' d. CAbstract:Based on the data of ERA5 reanalysis data from the European Centre for Medium-Range Weather Forecasts and the automatic meteorological stations in Zhejiang Province, we analyze the path and intensity of No. 14 typhoon "Chanthu" in 2021 and conduct a mechanical study of the forecast biases of its path and intensity. Moreover, the impact of typhoon "Chanthu" on the precipitation in Zhoushan is also discussed in this paper. The results show that the core area of typhoon "Chanthu" is small with broad peripheral circulation. The path deviation of typhoon "Chanthu" is mainly related to the subtropical high and continental high. The forecast of subtropical high is stronger and the southern branch of continental high is underestimated. The typhoon is surrounded by high pressure when it circles in the northern East China Sea without obvious steering flow. The higher SST provides thermal conditions for maintaining super and severe typhoon. The precipitation of typhoon “Chanthu”in Zhoushan are characterized by weak hourly precipitation intensity, long duration and considerable accumulated precipitation. The heavy rainfall in the southwest of Dinghai is mainly due to the influence of mountainous terrain and horizontal wind speed difference.0 v/ h. A1 l% X4 \  C4 |
Key words:typhoon "Chanthu"; subtropical high; heavy rainfall; path deviation; intensity
* \, E9 }, P. k. h: _9 H  |) U7 d
$ h0 U  {+ o- H7 Q# U- W  F
! s% w1 H8 A) z3 {7 u+ k# r- @& o
  t: o9 d2 s; J& u! j( H  V9 J# S% Y读者也可以通过公众号菜单栏
2 b% W/ C# ?# b% K0 o2 g' I( z* i; b“相关知识”板块进入《当期目录》和《过刊浏览》6 s: ?/ b' G8 k+ s& N
查阅详细期刊内容
1 y. }0 x% {1 n# R  ?未来两天海洋环境预报( B6 x1 s/ T3 ~
预计明天,
* w8 i" w1 @! Z' A渤海、黄海有1到1.8米的轻浪到中浪;
$ ~% ?& w4 i8 _东海北部有1.3到2.3米的中浪区;
/ B! o1 M& k4 ]; D  B5 S) R7 G东海南部、钓鱼岛附近海域有0.9到1.5米的轻浪到中浪;
, Q  y& u, j, ]台湾海峡、台湾以东洋面、巴士海峡、南海北部有1.5到2.2米的中浪;
  ?6 V7 [) e8 G2 R北部湾有1到1.5米的轻浪到中浪;
0 t1 |9 Z; ~8 u4 r1 j南海中部、南部有1到1.6米的轻浪到中浪。
: X2 n( S0 N3 O$ C9 u4 \5 U* F- N0 S1 G, U6 Q( g
预计后天,
# l8 b& d, ~1 k5 m" ^巴士海峡将出现大浪区,浪高2到2.7米。
7 h6 H0 o) G# p& t$ d' E, X) Q
0 o& A  a/ R1 Y
, L) K0 f8 A+ W. X  B" R' a- O) C) L$ X4 `) T
4月11~15日西北太平洋海浪数值预报
8 E: i/ P( x4 e; P3 n& I  }  ~美丽海岛海域海况/ F5 k! t, ^- k+ @0 \3 L( ]% @
预计明天,( a* Z& }) b4 G& ?# M  }$ @
平潭岛、东山岛附近海域有2.1米的中浪,以上海岛不适宜乘船出行;
- Z6 d7 }7 k- c5 l9 Z; Q$ A& n0 k湄洲岛、钓鱼岛、南澳岛附近海域有1.8~1.9米的中浪,长山群岛、灵山岛、嵊泗列岛、岱山岛、东极岛、普陀山、大陈岛、洞头岛、南麂岛、嵛山岛、万山群岛、黄岩岛附近海域有1.3~1.7米的中浪这些海岛较适宜乘船出行;
, }" p, B% }6 L我国其他各美丽海岛附近海域都是轻浪,海况不错,非常适宜乘船出行和海岛游玩。8 k% X* Z6 D' n# T3 X% @+ a
美丽海岛是指以下的35个海岛:
( ?) _& e7 w2 _) |" O觉华岛、长山群岛、菩提岛、长岛、刘公岛、灵山岛、秦山岛、连岛、崇明岛、嵊泗列岛、岱山岛、东极岛、普陀山、大陈岛、玉环岛、洞头岛、南麂岛、嵛山岛、三都岛、平潭岛、湄洲岛、东山岛、钓鱼岛、南澳岛、万山群岛、川山群岛、海陵岛、南三岛、东海岛、涠洲岛、分界洲岛、蜈支洲岛、永兴岛、黄岩岛、永暑礁。
# @( G$ p/ X/ Q3 y, Q1 ]+ c5 Z更多滨海旅游预报 尽在中国海洋预报$ i& X/ t/ ~0 h5 V% ~/ h' A
, D* c$ m/ `/ U" E' V' S. Q' G3 ^+ g
- C3 P' \3 I+ B- o* l
7 W1 u; O9 K* ^6 M! N- s. Y: ?( W8 HPC端可登录中国海洋预报网http://www.oceanguide.org.cn/IndexHome1 T' ?4 ]$ ?# `* w2 ~: z
) ]& O# M8 C; o2 B
1 v3 F' G# a/ g" o" `7 e) i- T
, \* a" q' ]  }* K
移动端可使用中国海洋预报微信小程序" U% u9 \5 k. X- ]; P2 l. N
进入“中国海洋预报”微信小程序
di86qae5r2
活跃在2021-7-25
