《海洋预报》| 基于梯度依赖OI的全球多参数Argo数据集的构建与验证
! C; Y! I7 b+ Q9 k9 |& x# k: i
) l' H' O% X' S1 _8 ?( p2 v4 _8 W
; u; q9 P, P( b9 k: z7 G6 \基于梯度依赖OI的全球多参数Argo数据集的构建与验证
6 A& A) O, N, r1 d: d全文请用PC端下载 地址:) m, e) M5 ~: e! `7 ^2 r% ?/ I* C6 H
6 x9 g7 q  E4 q5 f
http://www.hyyb.org.cn/Magazine/Show.aspx?ID=3471
1 T# [  w5 t( H# g3 c% z, }$ G  n读书小笔记+ g7 w: V) Z4 B6 _9 [5 w: D
作者:王丹阳1 张春玲1 2 卢少磊3 4 李兆钦3 4 刘增宏3 4
' Z7 M5 g0 h8 a单位:1. 上海海洋大学 海洋科学学院, 上海 201306;7 j9 F* ]" ^) F; L
2. 自然资源部海洋生态监测与修复技术重点实验室, 上海 201306;
  D* D, |9 B% L& Y% v5 y3. 自然资源部第二海洋研究所, 浙江 杭州 310012;
8 E- _2 k! E7 W0 m$ V1 L6 W, ?4. 卫星海洋环境动力学国家重点实验室, 浙江 杭州 310012) {4 O% w$ P' ^" a5 X) K
分类号:P715.2
" R! s" ]) e6 Y; r9 e出版年·卷·期(页码):2023·40·第二期(77-88): T& i) z, f8 J& l3 T
摘要:利用Argo资料,基于梯度依赖最优插值客观分析系统,重构2004—2020年空间分辨率为1°×1°的全球多参数Argo网格化数据集,并通过置信区间估计、实测数据检验、与其他数据集对比等方式,对该数据集进行一系列的验证。结果表明:重构的Argo数据集在95%的统计概率下,90%以上的温度、盐度重构结果可信,且与实测数据的温度、盐度最大偏差不超过±1.0℃、±0.02。该数据集所反映的大尺度信号与现有数据集一致,并且可以保留较多中小尺度信号,分析结果与实际观测更接近。8 p  g. \  m: R: D  z
关键词:梯度依赖最优插值 Argo 多参数 网格化数据集 客观分析% x- Q: b( i( A5 X2 M! H+ [
Abstract:Based on the gradient-dependent optimal interpolation objective analysis system, only, a global multiparameter Argo gridded dataset with a spatial resolution of 1°×1° from 2004 to 2020 is constructed using the Argo observation in this paper. A series of validations are made for this dataset including confidence interval estimation, observation inspection and comparison with other datasets. The results show that more than 90% of the reconstructed temperature and salinity are reliable under the statistical probability of 95% with the maximum bias from observations are less than ±1.0℃ and ±0.02, respectively. The large-scale signals reflected in this dataset are consistent with the existing datasets, and more small and medium-scale signals can be retained. The analysis results are closer to the observations.4 N. y9 o9 j6 R6 ?. ~
Key words:gradient-dependent optimal interpolation; Argo; multi-parameter; gridded dataset; objective analysis7 A: j5 B4 X+ ?% g5 k5 ]
( j& ~% ?1 |7 F, G
; t, l7 g1 a" W. u# M9 I, h
8 E& z5 S) I9 x$ @  _' N" t5 \
读者也可以通过公众号菜单栏
5 _' _$ K# z5 _5 O0 g“相关知识”板块进入
! @: t, x) [8 ]+ R7 b《当期目录》和《过刊浏览》
1 L& p1 O& y2 \: X. G9 d查阅详细期刊内容! O9 q  W* X7 n' U
未来两天海洋环境预报
5 c, b" S6 n6 p3 p6 l预计明天,
9 [# d4 @  c$ l, q5 j5 @渤海、黄海北部有0.4到0.7米的小浪到轻浪;
7 v! J7 {) v$ q3 V黄海南部有1.3到1.8米的中浪;$ x$ G% ^: A) G: v. ^. g& W
东海北部有1.2到1.6米的轻浪到中浪;3 b1 B* O2 W/ `2 o" \2 E$ a
东海南部、钓鱼岛附近海域有1.9到2.4米的中浪区;
% l- Z7 f" f. H+ I7 P& H/ A台湾海峡有1.5到2米的中浪区;' Y* J, Z' }  v1 S* C- _9 n# w
台湾以东洋面有1.6到2米的中浪区;
, u! h# T4 F% n/ `  `. S( P巴士海峡有0.8到1.1米的轻浪;8 b, w+ b* W+ c. g
南海北部、中部有1.2到1.6米的轻浪到中浪;, }* `6 D- @5 {- g
南海南部有0.7到1.2米的轻浪;
% D/ y" a# p5 V" V北部湾有1.4到1.7米的中浪。* y% A  o% p. l0 d! H* s" d
6 w1 |9 o6 X0 ^4 C% z
预计后天,$ X4 n& p1 X% l- t1 Z1 u
东海南部将生成新的大浪区,浪高1.7到2.5米。7 |$ N' [% r! w. O
0 Y, B0 o0 R+ \3 a
( k# a' q* }1 y1 T8 z* C
3 X( C2 P7 r3 u8 M
6月18~22日西北太平洋海浪数值预报4 u$ _* s5 n! p3 j! T
美丽海岛海域海况7 P8 e  o( w4 s& ]0 l: V
预计明天,, \8 |& O* `- {* i& r
灵山岛、洞头岛、南麂岛、嵛山岛、平潭岛、湄洲岛、钓鱼岛、川山群岛、海陵岛、涠洲岛、分界洲岛、蜈支洲岛、永兴岛附近海域有1.3~1.7米的中浪,较适宜乘船出行和海岛游玩;8 H' F) W- M; s+ ]( |$ o* e
( R( x0 Y7 t* z$ g" N
我国其他各美丽海岛附近海域都是轻浪,海况不错,非常适宜乘船出行和海岛游玩。. ?2 p% A$ c; Y+ L# z
) K4 P( o  X* y, E" N美丽海岛是指以下的35个海岛:
6 I9 u# T7 ~1 v2 ^觉华岛、长山群岛、菩提岛、长岛、刘公岛、灵山岛、秦山岛、连岛、崇明岛、嵊泗列岛、岱山岛、东极岛、普陀山、大陈岛、玉环岛、洞头岛、南麂岛、嵛山岛、三都岛、平潭岛、湄洲岛、东山岛、钓鱼岛、南澳岛、万山群岛、川山群岛、海陵岛、南三岛、东海岛、涠洲岛、分界洲岛、蜈支洲岛、永兴岛、黄岩岛、永暑礁。
) L, g+ }! c- ~5 ~) _更多滨海旅游预报 尽在中国海洋预报4 N+ |; d+ ^3 ~. X% _  W
# \. r2 u4 r+ F& h5 b
, Q7 f9 L0 O( |
- l. n/ ]8 P+ O$ S+ P: u: C& PPC端可登录中国海洋预报网http://www.oceanguide.org.cn/IndexHome6 Y$ Q, Z8 A2 w/ `! }( F4 t! b
* R/ C3 Q. O/ ^# {
4 i" J% r/ ^1 u+ u1 d7 a, T8 }  r
: T5 M' _8 A' |1 h- m. H- a移动端可使用中国海洋预报微信小程序6 A5 t+ ?; e3 g9 H3 y! S5 \% f
进入“中国海洋预报”微信小程序! j6 u- f, v( a3 y& r
进入“全球海啸预警”微信小程序
di86qae5r2
活跃在2021-7-25
