( H3 U, U$ o& \) v; G: g/ Y
+ `9 Q% \: |' B- f" M( ?; V6 b
* }( Z( F( _" z, s1 n9 m. Z- ^
+ |2 d& r, \; I4 i/ v5 z% i7 @2106号台风“烟花”的路径及降水特点分析& E: J2 o/ N. P# g5 J1 P1 b4 m5 T( @
全文请用PC端下载 地址:/ ~; q4 y4 g% _. C' i2 N7 ?
' a) x) Z5 M$ X7 ~- lhttp://www.hyyb.org.cn/Magazine/Show.aspx?ID=3485
! z M% p1 x6 x9 K* L8 J" {& I2 s读书小笔记# z0 b" Q; u: j* E
作者:项素清1 韩兴1 方鹤鸣2 姜涵3- G8 p3 [% \! S% I( d/ P0 |
单位:1. 浙江省金华市气象局, 浙江 金华 310002;' E9 T0 I7 o6 V4 ^
2. 金东区气象局, 浙江 金华 310002;
\ V! \0 n" h- A3. 浦江县气象局, 浙江 金华 322200
% C$ y* Y3 K% p# ]$ j4 @8 b3 Z3 }- I Z分类号:P444;P732.3* B2 o2 n; H- H% x+ H; c6 y
出版年·卷·期(页码):2023·40·第三期(75-84)& n- U& ?3 u* Z" j$ j. @8 i
摘要:2106号台风“烟花”(In-Fa)在浙江省两次登陆,影响时间从7月22日一直持续到28日,受其影响,浙江过程累积面雨量及单站雨量均破登陆浙江台风历史记录。通过分析发现:台风时段副热带高压位置比常年同期异常偏北,导致引导气流很弱,是造成台风“烟花”移速缓慢甚至在原地回旋的直接原因。2107号台风“查巴卡”和2108号台风“尼伯特”与台风“烟花”无直接互旋作用,而是通过对副热带高压强度和范围的影响,间接对台风“烟花”路径产生影响。西南季风向台风“烟花”持续输送水汽,是其登陆后强度得以维持的原因,台风在杭州湾长时间逗留,水汽供应有利于强度的维持。台风西侧云系在浙江上空受干侵入影响,减弱非常明显,形成非对称结构。对流有效位能很小,影响对流发展,小时雨强普遍较小,但由于台风“烟花”影响时间是一般台风的2倍,故累积雨量大。后期边界层辐合线的形成触发了对流的发展。地形对降水的增幅非常显著,累积雨量大的站点通常都位于海拔较高的山区,地形增水作用下站点雨量可达其他站点的2~3倍。
* N( o- S8 [+ [" J关键词:台风暴雨 非对称结构 西南急流 边界层辐合线 地形增水
* J+ V' E1 @4 ^# ]) p+ G0 b t0 g1 j% D
Abstract:The 2106 typhoon "In-Fa" landed twice in Zhejiang Province with its impacts lasting from July 22 to 28, the cumulative rainfall and single station rainfall in Zhejiang Province broke the historical record of typhoon in Zhejiang Province. Through this analysis, we find that the position of subtropical high during the period of the typhoon is abnormal norther than that in the climatology, which leads to a weaker guiding airflow further resulting in the slow movement speed of the typhoon "In-Fa". Typhoon 2107 "Chabaka" and typhoon 2108 "Nibert" have no direct interaction with the typhoon "In-Fa", but pose indirectly effect on the path of the typhoon "In-Fa" through affecting intensity and range of subtropical high. Continuously water vapor supplying to typhoon "In-Fa" by the southwest monsoon sustains the intensity of the typhoon "In-Fa" after landing, creating advantage condition for the long duration in Hangzhou Bay. The cloud system on the west side of the typhoon "In-Fa" encounters dry air over Zhejiang Province, leads to the weakening of the typhoon and forms an asymmetric structure. The convective available potential energy is low, thus limit the development of vertical convection and the intensity of hourly rainfall. The lasting period of the typhoon "In-Fa" is twice of those of general typhoons, so the cumulative rainfall is large. The increase in precipitation induced by land surface elevation is very significant. Stations with high cumulative rainfall usually locate in montanic areas with high altitude, and the rainfall reaches 2~3 times of those of other areas.* W0 o. w/ {, K i% B& K
Key words:typhoon rainstorm;asymmetric structure;southwest jet stream;terrain increase water1 t. o: N! J- s1 f2 S
& ^+ v0 c3 D' \/ F
6 c) p/ X2 f& O7 g2 T" l1 K3 J' L
读者也可以通过公众号菜单栏
, P- m5 K7 {4 K9 h; h" t“相关知识”板块进入" M }% ?' [. `5 b. @* X0 F6 D
《当期目录》和《过刊浏览》
# J0 b5 E4 E! M+ F$ k# L/ g8 G8 n$ B查阅详细期刊内容
) W0 y- ^$ P! l未来两天海洋环境预报3 J5 U% X9 k: w3 `) }
预计明天, `' }: }+ s, p8 T! ^* i
渤海有0.6到1.2米的轻浪;
, }7 M Q% b( R0 K6 s3 C" E, U黄海北部有1.1到1.5米的轻浪到中浪;
) b& _3 [( F5 ?) s& ~, Y: V d黄海南部有0.8到1.1米的轻浪;! M- Y4 O% \/ `: Z) |" B: t7 v
东海北部有0.9到1.3米的轻浪到中浪;
( e5 E/ U2 ~) X; _+ n5 P东海南部、钓鱼岛附近海域有1.7到2.2米的中浪区;7 t2 T; G7 C+ I; L* C
台湾海峡有1.6到2米的中浪区;
9 X3 U1 ]& z, n& e; Y+ E7 I台湾以东洋面有1.9到2.2米的中浪区;
' }6 U) r1 H' F5 H, Q巴士海峡有1.8到2米的中浪区;
) [+ a- ~, Y# m' U南海有1.5到2.2米的中浪区;
) a/ J1 @4 M9 S; O. ]! t; M- I北部湾有1到1.3米的轻浪到中浪。4 M5 A' M5 c- ]5 ?
: x! d, s0 ?/ `; b8 N Q1 I预计后天,
0 K* ?' {, j$ i& P8 D$ v我国近海无大浪区。+ h. Q$ N+ ~; v& t7 T
; z: x& K9 P' m) e
% ?0 A! K/ y6 {: Z H7 J8月12~16日西北太平洋海浪数值预报; w5 p, Z i- ]$ N: s; e2 k
美丽海岛海域海况, d. H3 k; Z0 }! C
预计明天,% B# k) X2 S3 x# t3 R. `
永兴岛、永暑礁附近海域有1.8米的中浪,东极岛、大陈岛、洞头岛、南麂岛、嵛山岛、平潭岛、湄洲岛、黄岩岛附近海域有1.3~1.7米的中浪,这些海岛较适宜乘船出行和海岛游玩;
4 l) l1 k2 _( ?' E我国其他各美丽海岛附近海域都是轻浪,海况不错,非常适宜乘船出行和海岛游玩。# D, P) U/ ^" p, J( g
7 v) Z$ f b) T$ O$ u- J美丽海岛是指以下的35个海岛:
# E& ~# \7 N* I) L: C; d$ c8 J觉华岛、长山群岛、菩提岛、长岛、刘公岛、灵山岛、秦山岛、连岛、崇明岛、嵊泗列岛、岱山岛、东极岛、普陀山、大陈岛、玉环岛、洞头岛、南麂岛、嵛山岛、三都岛、平潭岛、湄洲岛、东山岛、钓鱼岛、南澳岛、万山群岛、川山群岛、海陵岛、南三岛、东海岛、涠洲岛、分界洲岛、蜈支洲岛、永兴岛、黄岩岛、永暑礁。# [6 N, w3 l+ q9 P
更多滨海旅游预报 尽在中国海洋预报1 v( q7 M0 G: t$ U1 s, K4 Z; H( }8 `
+ C3 }+ P) R6 b# q$ f9 U9 \# i
" n. g: L& |% s6 X& S( c' r3 K) ZPC端可登录中国海洋预报网http://www.oceanguide.org.cn
/ V: P9 v t4 {. Z- U9 U9 O ~7 x! k0 O Z8 u
% A8 u+ A6 ]& n移动端可使用中国海洋预报微信小程序! F- e9 V. o) [0 O/ C: T
进入“中国海洋预报”微信小程序+ z0 l* t+ n) U( `; p
进入“全球海啸预警”微信小程序 |
