6 u+ o" @3 }0 ^7 O+ M
7 Z6 h& e7 R8 Q; W$ j4 f6 F; _- j2 @: j4 s" g! O. D4 c0 ^
; ^5 u; T/ S3 k* I0 z5 U渤海海域海上观测站逐时气温和气压的质量控制分析
z$ ]+ [+ w$ U9 F全文请用PC端下载 地址:
& Q, J( {+ H5 o b. ~2 J8 }3 X: t
% U* ?; G8 E" y3 r f7 x) n* Hhttp://www.hyyb.org.cn/Magazine/Show.aspx?ID=3487
' w+ Z* Q' L6 r& |1 M读书小笔记% b1 M$ N) [( }' D: S0 s
作者:王敏1 2 徐梅1 年飞翔1 任建玲1 黄纯玺1 郭阳1 勾志竟1
4 R, O1 W, g8 O单位:1. 天津市气象信息中心, 天津 300074;
* F. B- b" I5 O0 Y7 w4 \& Y' y, B2. 广东省韶关市气象局, 广东 韶关 512026
, q9 v) w. T" d分类号:P732.1
R' @4 t% O/ |0 e出版年·卷·期(页码):2023·40·第三期(97-103)
& f) c4 E' q" n( z' p; h摘要:为有效提高海洋观测质量,选取渤海海域2019年19个海上自动气象观测站的逐时气温和气压,利用界限值检查、气候变化范围检查、内部一致性检查、时间一致性检查和空间一致性检查方法,对数据进行质量控制分析。结果表明:逐时气压的数据质量优于逐时气温,所有站点逐时气压数据的可用率均在99%以上,而3个站点的逐时气温数据质量较差,可用率分别为88.9%、91.3%和92.3%,错误主要表现为连续一段时间内气温出现异常。经过质量控制剔除错误值后,站点观测资料数据与ERA5再分析资料的相关系数均有所提升;经质量控制后的观测气温和气压的均方根误差减小,相关系数增大。因此,经过上述质量控制方法可有效剔除不合理数值,避免其由于直接使用带来的偏差。
: P8 j% _% h4 i7 M+ k( o关键词:质量控制 逐时数据 海上观测站 气温 气压
/ s2 @8 L3 `+ q c' ?0 F; F4 P$ t/ q- i5 ]
Abstract:To effectively advance the quality of marine observation data, quality control analysis are applied to the hourly air temperature and pressure observations from 19 marine stations in the Bohai Sea in 2019. The quality control methods include maximum-minimum checking, climatological changing range checking, internal consistency checking, temporal consistency checking and spatial consistency checking. The results demonstrate that: the data quality of the observed pressure is better than that of the observed temperature, data availability rate of hourly pressure is above 99% for all the stations, however data availability rate of hourly temperature at 3 of the stations are relative low, with values of 88.9%、 91.3% and 92.3%, and the abnormal temperature data appears in a continuous period. Comparison between the hourly observations and ERA5 reanalysis data shows that, after applying the quality control analysis, the root mean square error between the observations and reanalysis data has decreased, and their correlation coefficient has increased. Therefore the quality control methods can effectively eliminate the unreasonable value of data.
1 j5 L0 d1 @$ `% Z3 _8 rKey words:quality control; hourly data; marine observation station; temperature and pressure
% t& w% {* Q- X
: ?- P: f6 F. k& {% u& [
6 B+ K/ P# B+ C3 s( v) \9 |# G; f读者也可以通过公众号菜单栏! ~3 \- B' e* T3 m- p7 X
“相关知识”板块进入# D5 y% X. o1 w7 B
《当期目录》和《过刊浏览》
4 p, ~3 F" w5 M/ K查阅详细期刊内容- A; w4 D0 Q* F( Z) G
未来两天海洋环境预报2 a1 I5 r# l- l' X
预计明天,/ p: e5 E" D( ]( k) P4 \( \4 F6 V& X
渤海、黄海、东海北部有0.6到1.2米的轻浪;
5 O: J7 \/ K5 Q东海南部、钓鱼岛附近海域、台湾海峡、台湾以东洋面、巴士海峡有1到1.8米的轻浪到中浪;3 v% |) u: |0 J
南海有1.3到1.8米的中浪;) `9 f s1 D) b0 A n% x/ `
北部湾有0.6到1.2米的轻浪。
* }8 z+ f+ L: p/ V5 [1 K& \2 E7 H, e
预计后天,, S" ^, M0 M- f( t7 E, \# B- i, n
我国近海无大浪区。
/ Z! {: ~6 L8 o& p) q8 T. |/ L4 e! U- f1 i+ s2 F. c t
) ?/ a3 U5 d' x3 W Q3 b
8月17~21日西北太平洋海浪数值预报
0 w+ Q" M! H! d美丽海岛海域海况
+ K# z% X: t- f1 l; Q8 |% g预计明天,' p, }% X6 u% k1 A* U8 A& C; d
永暑礁附近海域有1.9米的中浪,较适宜乘船出行;7 m% g. Q6 P# B; I5 C- M
+ `7 U! ^9 g5 y$ A, Q
我国其他各美丽海岛附近海域都是轻浪,海况不错,非常适宜乘船出行和海岛游玩。
$ ?. g& Q- f$ U: E* h4 L3 g) R2 H5 r$ A5 F7 w
美丽海岛是指以下的35个海岛:
' K3 R! l) u7 P; M3 y( R1 K+ k觉华岛、长山群岛、菩提岛、长岛、刘公岛、灵山岛、秦山岛、连岛、崇明岛、嵊泗列岛、岱山岛、东极岛、普陀山、大陈岛、玉环岛、洞头岛、南麂岛、嵛山岛、三都岛、平潭岛、湄洲岛、东山岛、钓鱼岛、南澳岛、万山群岛、川山群岛、海陵岛、南三岛、东海岛、涠洲岛、分界洲岛、蜈支洲岛、永兴岛、黄岩岛、永暑礁。
9 y4 p7 t/ B. z" d4 s- }更多滨海旅游预报 尽在中国海洋预报7 C. @: t: ?3 |* V2 _
* |( q9 g- H; Q! m' F D5 V" A2 W) w- `) [0 Q/ V+ ~
PC端可登录中国海洋预报网http://www.oceanguide.org.cn o: v) {& N, d7 C
" P' W7 I- y& z, [
/ V. w' w$ B1 N6 b9 i移动端可使用中国海洋预报微信小程序
( U& n* o5 l! W! b进入“中国海洋预报”微信小程序
/ q6 r+ a" M* H0 S( M* b! ?进入“全球海啸预警”微信小程序 |
