[数据处理] 海洋环境参数英语词汇大全,一文带你轻松掌握!
The ocean is a vast and complex ecosystem, influenced by numerous environmental parameters that shape its dynamics and biodiversity. Understanding these parameters is crucial for managing and preserving our marine resources. In this article, we will explore a comprehensive list of English vocabulary related to marine environmental parameters, providing you with essential knowledge to navigate the world of oceanography and marine science.
8 H4 s: @% T( Z0 x" w
) G, j+ r0 u) ?1. Temperature: The measurement of heat energy in the ocean. It plays a vital role in determining the distribution of marine organisms and is crucial for understanding oceanic circulation patterns.: b+ ^! z. S2 w3 C/ U: r) H' t
5 `% h/ B9 _! K, P9 M% c0 p! ]! \% n
2. Salinity: The amount of salt dissolved in seawater. Salinity levels influence water density and affect the movement of ocean currents. It also affects the physiology and behavior of marine organisms.
: N& G( T% |: F; F2 ?" C7 x: x. Q
9 z, |2 f- F5 B' `+ `% {* m. q3. Dissolved Oxygen: The concentration of oxygen dissolved in seawater. It is essential for the survival of marine life, as many organisms rely on oxygen for respiration. Low levels of dissolved oxygen can lead to hypoxia, causing harm to marine ecosystems.
$ ?6 T0 x4 J' U8 Y
7 z# s% E; C. b" G3 T. z, h/ @4. pH: A measure of the acidity or alkalinity of seawater. pH levels influence the growth and development of marine organisms, particularly those with calcium-based shells. Shifts in oceanic pH due to rising carbon dioxide levels can have detrimental effects on coral reefs and other marine life.% n2 @) i$ c. N2 ]* r& P
$ [; _. X) F8 w
5. Turbidity: The cloudiness or haziness of seawater caused by suspended particles. High turbidity limits light penetration, affecting photosynthesis and the distribution of organisms that rely on light for energy.
- b. ?, m( s1 q( T3 u4 A' G$ J3 c& `4 @( g$ h
6. Nutrients: Essential elements and compounds needed for the growth and survival of marine organisms. Nitrogen, phosphorus, and silica are examples of important nutrients in the ocean. Nutrient availability influences primary production and the overall productivity of marine ecosystems.
% [: A; d. ~% l* w/ _3 I* b+ M7 s% a4 z# s' O
7. Currents: The continuous, directed movements of seawater. Ocean currents can be driven by temperature, salinity, wind, and tides. They play a significant role in redistributing heat, nutrients, and marine organisms across the globe.$ f4 B; z' P3 d1 r* c) M
, a' w* b, F9 y! q8. Tides: The rise and fall of sea levels caused by the gravitational forces of the Moon and the Sun. Tidal patterns affect coastal ecosystems, influencing the distribution of intertidal organisms and the erosion of shorelines.% e9 K4 p( k# A& u7 r* r
% Q* K- H+ U2 W9 a% L+ M- _9. Wave Height: The vertical distance between the highest point (crest) and lowest point (trough) of a wave. Wave height is determined by wind speed, duration, and fetch (distance over which wind blows). It affects coastal processes, such as erosion and sediment transport.
) _' ~0 C9 E2 A8 f
2 D- P6 x: Y' c9 r6 ~10. Sea Level: The average level of the ocean's surface. Changes in sea level are influenced by factors such as climate change, melting glaciers, and thermal expansion of seawater. Rising sea levels can have significant impacts on coastal communities and ecosystems.
$ B6 T3 ~' X4 Y/ g
& t4 _% c. q( ^4 w8 r11. Dissolved Organic Matter (DOM): Organic substances derived from the breakdown of plant and animal material. DOM plays a crucial role in biogeochemical cycles, carbon sequestration, and the food web structure in marine ecosystems.
( J- j5 n: B8 K. l) N0 o; ]' p! `5 Z8 u! [" u$ [
12. Chlorophyll-a: A pigment found in plants and algae that enables photosynthesis. Chlorophyll-a concentration is used as an indicator of primary productivity in the ocean. It helps to monitor the health and vitality of marine ecosystems.
3 i- p: a$ ~: z$ x
% I3 ?( ]; J( [" v$ `13. Ocean Acoustics: The study of sound propagation in seawater. Understanding underwater sound is important for various applications, including communication among marine animals, naval operations, and detecting geological phenomena.
( U: u3 Z& w; d0 k4 C: C3 e  r5 i( Q+ G/ l$ g! v
14. Oceanic Pollution: The introduction of harmful substances into the marine environment. Pollution can come from various sources, such as oil spills, plastic waste, and chemical runoff. It poses a significant threat to marine biodiversity and ecosystems.
/ E( j7 _8 C: _/ ~& F" o7 q3 x0 j& r7 J+ o, `6 m
15. Biodiversity: The variety of life forms present in the ocean. Biodiversity is essential for maintaining ecosystem stability and resilience. It provides valuable resources and services, including food, medicines, and tourism.  x. T+ E2 L! M; U! {+ H% I
3 }8 O8 K& m/ W1 U* P
As you can see, the ocean environment is influenced by a multitude of parameters that interact with each other in complex ways. Understanding these parameters is essential for effective management and conservation efforts. By familiarizing yourself with the vocabulary related to marine environmental parameters, you will have a solid foundation for further exploration and study in the field of oceanography.
c8706997
活跃在2021-11-27
