德国HYDRO-BIOS公司——LIMNOS水样采集器 * p' }/ ]' n# J- W9 |2 b, }" z
LIMNOS Water Sampler
6 F) E& d- ?+ c; [+ W' h# K
- Y6 I/ E) g. \; ]. X+ G* P/ l1 v; N" b
LIMNOS水样采集器(玻璃采水器)是一款操作简单的水样采集器,采水器的取水深度30米。采水器LIMNOS水样采集器由PVC固定器和可更换的1000ml玻璃采样瓶组成。为了防止样品被表面水污染,将处在关闭状态的采水器LIMNOS水样采集器系在一根线缆上,沉入水中。当采水器达到预期深度时,使锤将会撞击铁砧,这时硅树脂管将会弹起,允许水样进入采水器的样品瓶,同时将空气排出。; v& j0 f0 c/ n5 Z4 j7 q0 k! ^
! M1 O1 v% y1 _# j
+ ]2 [) v( n' _LIMNOS水样采集器(玻璃采水器)订购信息:& K: t& P1 _* P3 f6 @
436 140 采水器LIMNOS水样采集器' K" I+ f+ U, H( I/ [2 o; x
采水器适用于30米水深,每套采水器带2个1000ml玻璃采样瓶和一个塑料包被的使锤3 u b9 g" a! f9 a& F$ C. Q" a" U& p
长288mm,宽65mm,高350,净重6.5kg
6 Q8 P2 w" X+ h j
5 l: A t9 u3 J# H# [$ ^0 Q436 145 采水器的玻璃采样瓶
" b n4 x- L4 I1 K2 X/ o5 _. j 采水器的采样瓶容积1000ml,适用水深30米,每个包装10只
6 t$ D# K# t) R. X) D+ [8 G* W6 m % e( I7 K* h/ X7 t
440 002 采水器上塑料包被的使锤
) \7 s/ M: l3 V, Z7 x6 e 孔径6mm,质量500g
) x' a/ ^$ U; c8 I" _; K; r8 c* \% l9 C0 t, T
3 _' Y2 y( j# w* ^6 p( ~2 W
代表文献:9 P/ E$ a H+ N# l
1.M. Raateoja1, J. Seppälä1, H. Kuosa2,2004.Bio-optical modelling of primary production in the SW Finnish coastal zone, Baltic Sea: fast repetition rate fluorometry in Case 2 waters.Marine Ecology Progress Series.267:9-26./ @/ u" K2 q$ c# B3 i/ ?
2.Rossberg, Marcelo; Wickham, Stephen A.,2008.Ciliate vertical distribution and diel vertical migration in a eutrophic lake.Fundamental and Applied Limnology / Archiv für Hydrobiologie.171:1-14.+ I- r9 ^+ Y. w& S. H
3.Hans Ulrik Riisgård, Coralie Barth-Jensen and Caroline V. Madsen,2010.High abundance of the jellyfish Aurelia aurita excludes the invasive ctenophore Mnemiopsis leidyi to establish in a shallow cove (Kertinge Nor, Denmark).Aquatic Invasions.5(4):doi: 10.3391/ai.2010.5.4.$ I5 }& m0 M" ]- l. u/ i
4.David A. Strand, Arne Holst-Jensen, Hildegunn Viljugrein, Bente Edvardsen, Dag Klaveness, Japo Jussila, Trude Vrålstad,2011.Detection and quantification of the crayfish plague agent in natural waters: direct monitoring approach for aquatic environments.Diseases of Aquatic Organisms.95:9-17.
2 Q" J& ]+ K* C3 D5.Iria Durán, Oscar Nieto,2012.Water characterization in three industrialized harbours (Vigo, Bilbao and Pasajes) in North Coast of Spain.Marine Pollution Bulletin.64(2):410-415.
6 G6 t% g9 C. T8 S% t4 V# G6.Christopher O. Miles, Morten Sandvik, Sigrid Haande, Hezron Nonga, and Andreas Ballot,2013.LC-MS Analysis with Thiol Derivatization to Differentiate [Dhb7]- from [Mdha7]-Microcystins: Analysis of Cyanobacterial Blooms, Planktothrix Cultures and European Crayfish from Lake Steinsfjorden, Norway.Environ. Sci. Technol..47(9):4080–4087.
. ^8 c& q+ z# @/ }3 e$ P4 p% B! _0 I. F H: [- c
% D! E2 y8 k; M' j' j更多关键字: LIMNOS水样采集器,采水器,水质采样器, 玻璃采水器,水体采样,德国HYDRO-BIOS公司,有机玻璃采水器
: E9 F! T" V" o( P1 \ ?; R& ~5 O5 ^" U
<strong> |
