海洋科学中常见的测深仪英文名称有哪些?
In the field of oceanography, measuring the depth of the ocean plays a crucial role in understanding the marine environment and its various phenomena. To accomplish this task accurately and efficiently, scientists and researchers rely on different types of depth measurement instruments, commonly referred to as echo sounders or sonar systems.
- n7 P  {7 r! t
+ d5 x, K9 T. VOne widely used instrument is called a single-beam echo sounder. As the name suggests, this device emits a single acoustic pulse downward from a transducer and measures the time it takes for the pulse to return after bouncing off the seafloor. By knowing the speed of sound in water, which is approximately 1500 meters per second, the depth can be calculated. Single-beam echo sounders are relatively simple and cost-effective, making them suitable for general-purpose depth measurements in shallow waters.
5 L- M: k3 t; ^/ B! Z1 w6 L& t0 x$ a  C8 S  O
For more precise and detailed measurements, multi-beam echo sounders are employed. These advanced instruments utilize an array of transducers to emit multiple acoustic pulses simultaneously in a fan-shaped pattern. The echoes received from different angles allow for the creation of high-resolution bathymetric maps with accurate depth measurements. Multi-beam echo sounders are commonly used in offshore surveys, underwater mapping, and navigation applications.) t1 |4 @& z. `
+ O1 D- P2 u' _In recent years, the development of interferometric sonar systems has revolutionized depth measurement capabilities. Interferometric systems work by measuring the phase difference between two or more overlapping acoustic pulses to determine the seafloor depth. This technique provides highly accurate and precise depth information, even in challenging underwater terrains. Interferometric sonars are widely used in hydrographic surveys, subsea infrastructure inspections, and marine research activities.$ ?! _- [0 i8 V6 r5 N! @% V
% d& i1 T+ c8 x7 \
Another essential depth measurement instrument is the profiling sonar. It is specifically designed for real-time monitoring of underwater structures such as bridges, piers, and oil platforms. Profiling sonars use a combination of acoustic technology and advanced data processing algorithms to generate continuous depth profiles and detect any changes or anomalies in the underwater environment. These instruments ensure the safety and integrity of marine structures by providing valuable information for maintenance and inspection purposes.* A5 J# X) a3 h4 o- Q4 c1 g
/ a  e' Q+ c5 w( X8 pIn addition to these commonly used depth measurement instruments, scientific expeditions and research vessels often employ remotely operated vehicles (ROVs) or autonomous underwater vehicles (AUVs) equipped with sonar systems. These underwater robots are capable of collecting high-resolution bathymetric data in real-time, allowing scientists to explore and map previously inaccessible ocean regions.; d; Q8 p, H0 }) v
8 z( l0 S+ w; h, V8 Q2 v3 c. H: x
It is important to note that various manufacturers produce these instruments, each with their own unique names and specifications. Some well-known companies in the field of oceanographic instrumentation include Kongsberg Maritime, Teledyne Marine, and R2Sonic. Their echo sounders and sonar systems are widely recognized and utilized in both scientific research and commercial applications, ensuring accurate depth measurements and contributing to our understanding of the marine world.
* F8 A2 t* b/ m+ S' M- C8 }% e+ A) q' z5 k* r
To conclude, the field of oceanography relies on a range of depth measurement instruments, including single-beam echo sounders, multi-beam echo sounders, interferometric sonars, profiling sonars, as well as ROVs and AUVs equipped with sonar systems. Each instrument serves specific purposes and offers different levels of accuracy and resolution. By utilizing these advanced technologies, researchers can acquire comprehensive knowledge of the underwater environment and contribute to the sustainable management of our oceans.
荣嘉歆
活跃在2021-12-1
