3 F5 O- i" C: J5 _6 z/ j6 {6 E
: X* {' q6 J A: r0 r6 Y登陆台风外围极端降水过程的中α尺度系统特征
* K: O# }/ \% ?. s8 ^全文请用PC端下载 地址:5 W8 s$ ~" `2 G# R+ e
: a8 b$ r4 A, X/ T) ?: y1 F; b
http://www.hyyb.org.cn/Magazine/Show.aspx?ID=3528
$ k! m; M$ [+ G5 Y9 @: o' B! o5 o读书小笔记
2 p& i! K! N0 U. Q. A* c: [) ^作者:李君1 2 胡晓琳1 2 丛春华1 3
7 n6 b& \) S% i单位:1. 山东省气象防灾减灾重点实验室, 山东 济南 250031;
|- O. l6 z N" m E R4 \% w& E2. 山东省淄博市气象局, 山东 淄博 255000;
( K4 X; U: r3 n& P3. 山东省气象台, 山东济南 250031
# e6 A. \. m: _( }分类号:P445) k! ]4 S2 g$ t" ?" p4 d6 @" p
出版年·卷·期(页码):2023·40·第六期(102-114)
+ Q: p, ]. G& |2 B/ |) c c% g摘要:采用全国多普勒雷达反射率因子拼图、山东省自动气象观测站数据,结合ERA5 0.25°×0.25°再分析资料,分析台风“利奇马”造成山东极端暴雨的中α尺度系统特征。结果表明:台风北侧东南急流与西风槽后偏西气流的切变引发的中α尺度辐合区是直接造成极端降水的中尺度系统;对流始于800~750 hPa,随后沿西风槽向高层发展,再伸展到低层,在台风北侧低层切变附近强烈发展;初始对流由低空急流触发,后高空出流迅速增强,促进上升运动发展,高低空急流上下耦合的正反馈作用促进了中α尺度辐合区深度发展,是极端降水发生发展的重要原因;初始对流发生在对流不稳定环境中,凝结潜热释放造成的湿斜压性和中低层垂直切变形成的条件性对称不稳定增长,使对流发展为有组织而长时间维持的深对流;水平风场将水汽汇集向暴雨区,上升运动将水汽向中高层输送,湿层逐渐增厚,当水汽通量15 g/(cm·hPa·s)等值线向上伸展到500 hPa时,降水强度超过20 mm/h;鲁中山区地形是影响降水中心落区的重要因素。
" ]3 Y N/ Q7 L* P3 {关键词:台风“利奇马” 中α尺度系统 高低空急流 条件性对称不稳定 水汽 地形5 N7 `( d; |# W
Abstract:This paper uses puzzles of the national Doppler radar reflectivity, data from regional automatic weather observation station, combined with NCEP/NCAR 6-hour daily re-analysis data, to analyze the mesoscale convective system that caused extreme rainstorms in Shandong by Typhoon "Lekima" and found:The mesoscale convergence system caused by the shear of the southeast jet on the north side of the typhoon and the westward airflow after the westerly trough is the mesoscale system that directly causes extreme precipitation. Convection starts from 800~750 hPa and then develops along the westerly trough to the upper layers, Extending to the lower level, it develops strongly near the low-level shear on the north side of the typhoon. The initial convection was triggered by the low-level jet stream, and the outflow increased rapidly after the upper level, promoting the development of upward motion. The coupling positive feedback effect of the upper and lower air jet stream promoted the depth development of the middle α scale convergence zone, which is an important reason for the development of the extreme precipitation. During the development of the mesoscale system, there is an obvious high-level dry and cold air intrusion from the northwest, and the upper layer is ahead of the lower, which is conducive to the enhancement of instability and promotes the formation and development of mesoscale system,which in turn increases precipitation. When the height of dry and cold air invades into 500 hPa, initial convection appears. The lower intrusion height, the more precipitation, and the most precipitation appears in the boundary layer. The horizontal circulation concentrates the water vapor to the heavy rain area. The vertical upward movement of the mesoscale convergence system transports the water vapor to the middle and upper layers, and the wet layer gradually thickens. When the contour of the water vapor flux 15 g/(cm · hPa · s) extends upward to 500 hPa, the precipitation intensity increases to more than 20 mm/h. The terrain of central Shandong mountain is an important factor affecting the central precipitation area.4 R7 a$ C2 }) c* g$ I
Key words:Typhoon "Lekima"; alpha mesoscale; high and low jet; conditional symmetrical instability; water vapor; terrain0 e2 m/ m4 U$ ]- {
- v' _6 z) c$ |( g/ t$ X; f1 D, Z& I# c* u0 e3 U' N
读者也可以通过公众号菜单栏
7 e( a; @( X" r9 I( R+ u i“相关知识”板块进入《当期目录》和《过刊浏览》+ u, s& h3 C( b
查阅详细期刊内容
! P* M; E5 B. Z+ |. h, e未来两天海洋环境预报8 o+ L6 u ^4 R$ J
预计明天,
# y7 |( i- g8 z; R渤海、黄海北部有0.6到1.3米的轻浪到中浪;
+ z) L! [+ i: X东海东北部有2到3.5米的中浪到大浪区; x/ i) L4 h8 F1 \% x6 w
东海西北部、南部、台湾以东洋面有1.3到2.3米的中浪区;7 H+ Q" l! |; \$ a
台湾海峡有1.8到2.4米的中浪区;) f: \" W( a3 ^, N; C
巴士海峡、南海北部、中部有2到3米的中浪到大浪区;
# ^2 F) b/ H7 d南海南部有1.8到2.4米的中浪区;- v: d o% y7 |4 B M7 p& z+ w
北部湾有0.9到1.5米的轻浪到中浪。2 @( m+ B4 L$ F7 V7 ^1 p' k
预计后天,
B% V1 j4 S$ a8 h' t黄海将生成新的大浪区,浪高2到3.5米;! X: \5 s9 |" Z8 i3 J( e7 g
东海东部大浪区维持,浪高3到4.5米;1 ?* \/ M- v+ _( H! E
台湾海峡大浪区维持并扩展至台湾以东洋面,浪高2到3.3米;& L+ p0 b% U) E
南海大浪区减弱消失。+ t" t- o/ m0 E$ h
& Q7 ~0 X. _% X0 t; [) Y: H2 c. L. A" i
2月27日~3月2日西北太平洋海浪数值预报
; v5 c' B# T4 X" R/ q% n/ o- K美丽海岛海域海况0 C5 m- F Y( _0 W
预计明天,
/ I2 k1 q2 e% I4 x永兴岛、永暑礁附近海域有2.2~2.4米的中浪,以上海岛不适宜乘船出行;* @ R+ w3 S# B( j! M. P
东极岛、东山岛、钓鱼岛、川山群岛、分界洲岛、蜈支洲岛、黄岩岛附近海域有1.8~2米的中浪,灵山岛、连岛、普陀山、大陈岛、洞头岛、南麂岛、平潭岛、湄洲岛、南澳岛、万山群岛、海陵岛、南三岛、东海岛附近海域有1.3~1.7米的中浪,这些海岛较适宜乘船出行和海岛游玩;: |3 M: \7 V7 |# I) [1 V- Z3 G& z
我国其他美丽海岛附近海域都是轻浪,海况不错,非常适宜乘船出行和海岛游玩。
$ R' S" o# o0 p( O! v' |9 i
! J- Q, j. @+ x3 r1 V7 @% t' r4 o1 _美丽海岛是指以下的35个海岛:
2 w7 S+ i5 l4 N$ ]0 @6 L4 f- N' I觉华岛、长山群岛、菩提岛、长岛、刘公岛、灵山岛、秦山岛、连岛、崇明岛、嵊泗列岛、岱山岛、东极岛、普陀山、大陈岛、玉环岛、洞头岛、南麂岛、嵛山岛、三都岛、平潭岛、湄洲岛、东山岛、钓鱼岛、南澳岛、万山群岛、川山群岛、海陵岛、南三岛、东海岛、涠洲岛、分界洲岛、蜈支洲岛、永兴岛、黄岩岛、永暑礁。: T7 T* t6 W# | g: q4 T
更多滨海旅游预报 尽在中国海洋预报
8 g$ ?- Y$ H! t) _' I8 N, N
2 C" }. Y9 B# ]' i9 n/ x1 ]& i: k, J
6 F+ G6 z1 E0 a; @PC端可登录中国海洋预报网http://www.oceanguide.org.cn4 Q8 O z2 |5 w" M8 t) k
5 v0 x3 n, p( o* ?0 o( K) z- d* A
- F y) N3 B- [9 X7 Q
移动端可使用中国海洋预报微信小程序8 l+ \% v' P- y8 z2 E% ~) W; f
进入“中国海洋预报”微信小程序
7 |1 c; Q4 n4 T$ N4 e1 Q2 I0 I进入“全球海啸预警”微信小程序 |
