GMT和Pygmt提供了一个远程数据功能,可以使用函数datasets远程下载多种在线数据,并进行处理和绘图。这里以pygmt为例绘制海底地壳年龄、陆地地形。 地壳数据[1]包含了不同的分辨率,对应不同文件大小,最粗为1d,全球数据仅125K,最大分辨率1m,全球数据188M。绘图& e0 z3 B& s" Q5 E3 X. J
[C] 纯文本查看 复制代码 import pygmt
grid_globe = pygmt.datasets.load_earth_age(resolution='06m', region="-180/180/-90/90", registration=None)
fig = pygmt.Figure()
fig.grdimage(grid=grid_globe, projection="R15c", region="0/360/-89/89", frame=True,cmap="crustal_age.cpt")
fig.colorbar(frame=["af", "x+lage", "y+lMyr"],cmap="crustal_age.cpt")
fig.show() 6 o, [/ H, L8 c" L0 G" {
$ V& z9 a& H& E) I
/ C8 T1 x2 K2 u* ^上面的调色板crustal_age可以在.gmt/cache/下找到,而远程数据也下载到了./gmt/server/下面。* E2 y7 j- e- P
地形数据地形数据[2]包含多种不同分辨率,对应不同的文件大小,最粗为1d,文件大小128k,最高分辨率为1s,文件大小达41G: SRTM绘图[C] 纯文本查看 复制代码 # 雅鲁藏布江大峡谷[/b]grid = pygmt.datasets.load_earth_relief(
"03s",
region=[94, 95.5, 29, 30],
registration="gridline",
use_srtm=True,
# calculate the reflection of a light source projecting from west to east
# (azimuth of 270 degrees) and at a latitude of 30 degrees from the horizon
dgrid = pygmt.grdgradient(grid=grid, radiance=[270, 30])
fig.grdimage(grid=grid, projection="M15c", region=[94, 95.5, 29, 30], frame=['WSrt+t"Original Data Elevation Model"',"xa", "ya"],cmap="dem1")
fig.colorbar(position="JML+o1.8c/0c+w10c/0.9c",frame=["af", "y+lmeter"])
fig.coast(rivers="a/1p",borders="2/5,red")
# Shift plot origin of the second map by 12.5 cm in x direction
fig.shift_origin(xshift="20c")
pygmt.makecpt(cmap="gray", series=[-1.5, 0.3, 0.01])
fig.grdimage(
grid=dgrid,
projection="M15c",
frame=['lSEt+t"Hillshade Map"', "xa0.1", "ya0.1"],
cmap=True,
fig.grdimage(
grid=grid,
shading=dgrid,
projection="M15c",
cmap="dem1",
fig.show(width="20c")
fig.savefig("srtm.png")
+ ? Y7 l3 Y3 n3 K) O3 W" W+ W9 U9 x; k- \( r# g2 A5 _2 X
3 p/ ?5 C( f& h4 o( @1 ]
+ V& p! ?. K* h$ [2 f3 I3D地形图
7 i% |* _2 D$ ^[C] 纯文本查看 复制代码 fig = pygmt.Figure()
fig.grdview(
grid=grid,
region=[94.7, 95.2, 29.5, 30],
perspective=[250, 60],
frame=["xa", "ya", "WSNE"],
projection="M15c",
zsize="15c",
surftype="s",
cmap="dem1",
# Set the plane elevation to 1,000 meters and make the fill "gray"
plane="000+ggray",
fig.show()
3 h F& b# B) {5 K
# @5 n: [9 q9 L" {$ u% q" P, K% e同样,我们还可以使用pygmt.grdview绘制三维地形图。下面是我曾经到过山脚下,但是在云中的南迦巴瓦峰。
4 c7 u5 U. i) ]/ V" w
$ s6 }2 C$ l9 \6 M! C
5 s( }5 o h6 E# m8 z' I* l C2 \' |' x. M- Q" T4 U; C
附:遥感影像和地形的结合在github存在一个30Day*****的系列代码库,其中包含绘图领域的30DayMapChallenge2021,恰好已经使用GMT完成了这项工作,作者是Pygmt的核心开发者Weiji。 这里有两个遥感影像和地形结合的例子(17和18),可以作为很好的学习材料.
) O9 I7 }( [# V! y% |/ k4 k; L
! ~9 [5 [4 ]9 [+ k+ ]. J+ |; E) x; n! X' R# i, A
References[1] 地壳数据: https://www.generic-mapping-tools.org/remote-datasets/earth-age.html# e( [6 f+ k/ k3 m
[2] 地形数据: https://www.generic-mapping-tools.org/remote-datasets/earth-relief.html& f% k0 K5 t/ {/ o+ |, K# E6 F
- E9 j w) d, I' s- }
来源:海洋遥感数据共享- _& Q9 M/ t3 ?" F- [8 t" a" U
' Z6 g; x/ `$ j& p |
