【浮游生物类仪器】德国HYDRO-BIOS公司 浮游动物计数框
德国HYDRO-BIOS公司——浮游动物计数框
1 C% x2 P2 H1 u6 v3 ~5 K; KCounting Chamber for zooplankton
( }& B0 j! f/ d+ n2 z/ E' g
' _2 h. N3 p  p$ Y3 Q
4 X5 {6 t' e3 w! Y6 @1 q
/ `! W' \: e: Z0 [
8 B1 L2 Q3 Z: [* N浮游动物计数框用于在体式显微镜底下对浮游动物进行观察计数。浮游动物计数框由树脂材料制成,底面抛光,具有较好的透明度,可将其放置到常规显微镜上对浮游动物进行观察。- ]! F( B* s1 |! R! C# V- t
& N- k. n" y* |; N; x, M
& r4 G6 f- E7 T6 `: d# Q8 a
  c8 s( f! z& I# Y. t4 j
9 j( S0 e" O) Z8 @浮游动物计数框订购指南:- J6 X  [9 |$ X+ O- v4 B- @1 {
浮游动物计数框由树脂材料制成,底面抛光,具有很好的透明度, `, o  R4 [/ V  S5 `, ^
! ^/ ~. A, L* K
# y) B  A. j+ j" R2 d& U: d) o        435 010     浮游动物计数框尺寸40×70mm,容纳样品量约9ml! p+ X$ }6 s3 g0 w) D
. T. R- V4 i0 D) G4 d3 X
+ D' Z& j4 o: k# C' u8 W
        435 011      浮游动物计数框尺寸80×100mm,容纳样品量约22ml
' ~' @. B9 Y6 l3 u( l5 H2 M        435 011A   浮游动物计数框尺寸80×100mm,容纳样品量约6×5.4ml
, K: n+ N( V, m: d        435 011B   浮游动物计数框尺寸80×100mm,容纳样品量约12×2.4ml
2 f' b4 _% j& n0 B        435 011C   浮游动物计数框尺寸80×100mm,容纳样品量约30×0.8ml
! i8 C# s7 x5 A) k& l. L0 b
( B, W# _' U% Z9 L& w! t$ }( M6 P
8 w( Q9 i# S5 g* t. e5 s* C
        435 012    浮游动物计数框尺寸80×140mm,容纳样品量约70ml
- t& a) Q5 Z$ @4 H$ ~# ]+ \1 J9 f& z& |6 x& `
! q, X- e' D! D9 `& Q$ D" Y% a
代表文献:/ i& Q& _; y2 @  G
1.Manfred Rolke and Jürgen Lenz,1984.Size structure analysis of zooplankton
. |! G/ W4 Q' @0 r
samples by means of an automated image analyzing system.Journal of Plankton Research.6(4): 637-645./ C0 C8 _+ |1 \2 u  \8 K
2.Austin B.M. Egborge and Prekeyi Tawari,1987.The rotifers of Warri River, Nigeria.Journal of Plankton Research.9(1):1-13.: K+ T" Y- j, E  g: [
3.J.W. Rijstenbil,1987.Phytoplankton composition of stagnant and tidal ecosystems in relation to salinity, nutrients, light and turbulence.Netherlands Journal of Sea Research.21(2):113–123.
9 S6 K8 i6 w9 t* t+ j3 z4.S. Wagener, C. F. Bardele, N. Pfennig,1990.Functional integration of Methanobacterium formicicum into the anaerobic ciliate Trimyema compressum.Archives of Microbiology.153(5):496-501.
2 a9 `: z  w. T6 v, m/ c5.S. Holler, N. Pfennig,1991.Fermentation products of the anaerobic ciliate Trimyema compressum in monoxenic cultures.Archives of Microbiology.156(4):327-334 .: `/ P! A5 H* N
6.J. W. Rijstenbil, C. Bakker, R. H. Jackson, A. G. A. Merks, P. R. M. de Visscher,1993.Spatial and temporal variation in community composition and photosynthetic characteristics of phytoplankton in the upper Westerschelde estuary (Belgium, SW Netherlands).Hydrobiologia.269-270(1):263-273.- I( Y- _; k; S
7.Bettina Meyer-Harms, Falk Pollehne,1998.ALLOXANTHIN IN DINOPHYSIS NORVEGICA (DINOPHYSIALES, DINOPHYCEAE) FROM THE BALTIC SEA.Journal of Phycology.34(2):280–285.3 k) V! }$ @- i( H
8.Catalina Castell Perez, Suzanne Roy, Maurice Levasseur, Donald M. Anderson,1998.CONTROL OF GERMINATION OF ALEXANDRIUM TAMARENSE (DINOPHYCEAE) CYSTS FROM THE LOWER ST. LAWRENCE ESTUARY (CANADA).Journal of Phycology.34(2):242–249.
3 i7 b+ ]0 i% q: E! i9.Teresa Cruz and Jorge Araújo,1999.Reproductive Patterns of Pollicipes pollicipes (Cirripedia: Scalpellomorpha) on the Southwestern Coast of Portugal.Journal of Crustacean Biology.19(2):260-267.
: [2 ]+ F2 J3 v, u" O+ e10.Michael Hust, Wolfgang E Krumbein, Erhard Rhiel,1999.An immunochemical in situ approach to detect adaptation processes in the photosynthetic apparatus of diatoms of the Wadden Sea sediment surface layers.Journal of Microbiological Methods.38(1–2):69–80.( }! p" B" w# J( n+ l+ S
11.Christine Dupuy, Solange Le Gall, Hans J. Hartmann, Martine Bréret,1999.Retention of ciliates and flagellates by the oyster Crassostrea gigas in French Atlantic coastal ponds: protists as a trophic link between bacterioplankton and benthic suspension-feeders.Marine Ecology Progress Series.177:165-175.1 o1 D( O. D% ?, C8 y/ t
12.A. Tewari, H.V. Joshi, R.H. Trivedi, V.G. Sravankumar, C. Raghunathan, Y. Khambhaty, O.S. Kotiwar, S.K. Mandal,2001.The Effect of Ship Scrapping Industry and its Associated Wastes on the Biomass Production and Biodiversity of Biota in in situ Condition at Alang.Marine Pollution Bulletin.42(6):461–468.
9 M1 |# l) _; U) \5 @' X: B) X2 X13.Hera Karayanni, Urania Christaki, France Van Wambeke, Andrew P. Dalby,2004.Evaluation of double formalin—Lugol's fixation in assessing number and biomass of ciliates: an example of estimations at mesoscale in NE Atlantic.Journal of Microbiological Methods.56(3):349–358.
3 _3 z( K" p! k4 f) p14.EI Ohimain, TOT Imoobe & MO Benka-Coker,2005.The impact of dredging on macrobenthic invertebrates in a tributary of the Warri River, Niger delta.African Journal of Aquatic Science.30(1):49-53.
3 q9 Q" J4 h- A; j15.Laurent Seuront, Dorothée Vincent, James G. Mitchell,2006.Biologically induced modification of seawater viscosity in the Eastern English Channel during a Phaeocystis globosa spring bloom.Journal of Marine Systems.61(3–4):118–133.3 n( f' m) W' f& v( P
16.Wim A.M. Hijnen, Yolanda J. Dullemont, Jack F. Schijven, Anke J. Hanzens-Brouwer, Martine Rosielle, Gertjan Medema,2007.Removal and fate of Cryptosporidium parvum, Clostridium perfringens and small-sized centric diatoms (Stephanodiscus hantzschii) in slow sand filters.Water Research.41(10):2151–2162.- h. K; ?4 F9 O& E0 V# S% S, l, Y
17.Géraldine Sarthou, Dorothée Vincent, Urania Christaki, Ingrid Obernosterer, Klaas R. Timmermans, Corina P.D. Brussaard,2008.The fate of biogenic iron during a phytoplankton bloom induced by natural fertilisation: Impact of copepod grazing.Deep Sea Research Part II: Topical Studies in Oceanography.55(5–7):734–751.
& M* q% }( o# Y" t18.Damir Viličić, Tamara Djakovac, Zrinka Burić, Sunčica Bosak,2009.Composition and annual cycle of phytoplankton assemblages in the northeastern Adriatic Sea.Botanica Marina.52(4):291–305.; [" s1 K5 O, E$ R- K
19.Fedekar F. Madkour, Mohsen M. El-Sherbiny and Maher A. Aamer,2010.Phytoplankton population along certain Egyptian coastal regions of the Red Sea.Egypt J. Aquat. Biol. & Fish..14(2):95-109.
" E( \- o: v7 p1 f20.Mianrun Chena, Bingzhang Chena, Paul Harrisonb, Hongbin Liu,2011.Dynamics of mesozooplankton assemblages in subtropical coastal waters of Hong Kong: A comparative study between a eutrophic estuarine and a mesotrophic coastal site.Continental Shelf Research.31(10):1075–1086.( q9 W2 o, C. l0 f
21.Germán A. Kopprio, Gerhard Kattner, Martin Graeve, R. Hugo Freije, Rubén J. Lara,2012.Exceptional lipid storage mode of the copepod Boeckella poopoensis in a pampean salt lake, Argentina.Aquatic Biology.15:275-281.% _: J+ {; ]0 R2 O' D' O* y
22.Dongyan Liu, Yajun Shi, Baoping Di, Qianli Sun, Yujue Wang, Zhijun Dong, Hongbing Shao,2012.The impact of different pollution sources on modern dinoflagellate cysts in Sishili Bay, Yellow Sea, China.Marine Micropaleontology.84–85:1–13.
) U# t6 ~# h8 j2 h) i23.Daniel Remias, Andreas Holzinger, Siegfried Aigner, Cornelius Lütz,2012.Ecophysiology and ultrastructure of Ancylonema nordenskiöldii (Zygnematales, Streptophyta), causing brown ice on glaciers in Svalbard (high arctic).Polar Biology.35(6):899-908.
; i' ?( Q6 \4 s5 w7 K  P( [24.F.S. Tahami, A.G. Mazlan, H. Negarestan, Sh. Najafpour, W.W.M. Lotfi and G.D. Najafpour,2012.Phytoplankton Combination in the Southern Part of Caspian Sea.World Applied Sciences Journal.16(1): 99-105.) f8 |) I4 |) i' T3 P' M$ X
25.Amir Abbas Bazyar Lakeh, Werner Kloas Rainer Jung, Ra’anan Ariav, Klaus Knopf,2013.Low frequency ultrasound and UV-C for elimination of pathogens in recirculating aquaculture systems.Ultrasonics Sonochemistry.20(5):1211–1216.
- ^! m+ [+ f: q4 U
/ e9 k  _: _6 p6 H/ D9 X
0 c' Q* p+ c4 d+ u更多关键字: 浮游动物计数框,浮游生物计数框,浮游生物观察组件
" K% T& X2 |9 z! E# H9 \0 D0 _* j, H% W
6 y6 p3 A# t# J( e9 A1 ^; b
+ K3 @# t8 _- ?! H& A% }
<strong>
oceaner
活跃在2026-1-19
