德国HYDRO-BIOS公司——Kolkwitz浮游植物计数框 . p5 w) ]# g. t3 P
0 Z$ _; E9 o# r' P% @# Q; o/ C8 H: o, A' c& J- n6 s
0 U* b, C9 a& \! \$ X/ ~: H
7 `7 e6 I4 S4 z1 A% b
) q e& @% x! z+ j Kolkwitz浮游植物计数框用于在倒置显微镜下对浮游植物进行观察计数。: j$ j; G- s) ]
* G9 G- P% I) O( r! b ~+ JKolkwitz浮游植物计数框订购指南:% V8 h2 F5 Y @# p8 Q- i( f
435 015 Kolkwitz浮游植物计数框
; L2 g6 r1 T6 R a K: F 包含带计数网格的盖片
* @& a' K# ~% B" l8 I. v* |9 H 网格大小 1×1mm
( v) ?5 \8 g0 K1 A 尺寸 33×33mm
7 h) h7 C8 v' L5 ]& k9 D 盖玻片厚度 1.3mm- v, M: ?; o7 G: T2 V ~, `8 g
计数孔直径22mm$ u% \% x! b' b- Z2 X. {
样品容量0.5ml(经过精确校准的)
4 M' p& f# _7 Y: f# E# J ^: W- u$ |8 W7 |+ k( _# l* c& @1 ?6 N
435 016 Kolkwitz浮游植物计数框
+ m, M, D. l& K0 T" B5 C" h 包含带计数网格的盖片 O3 q" Y7 F) Z& W& K2 P: s
网格大小 1×1mm: x/ v9 M0 i6 |, U4 b
尺寸 33×33mm
: K& l' p/ R6 L: } 盖玻片厚度 2.6mm# A0 l5 u+ m* c7 w0 I' S& O
计数孔直径22mm
0 `4 Y. `/ |8 R 样品容量1.0ml(经过精确校准的)( T7 Q9 F$ v& X) o8 ]5 R
" r$ K7 R7 S1 V- ^代表文献:
# o5 p9 K, O9 b" T- B/ W1.Manfred Rolke and Jürgen Lenz,1984.Size structure analysis of zooplankton samples by means of an automated image analyzing system.Journal of Plankton Research.6(4): 637-645.; S/ m$ e) ~! y+ a9 L% v) t
2.Austin B.M. Egborge and Prekeyi Tawari,1987.The rotifers of Warri River, Nigeria.Journal of Plankton Research.9(1):1-13.& ~% A1 \' w/ W6 {
3.J.W. Rijstenbil,1987.Phytoplankton composition of stagnant and tidal ecosystems in relation to salinity, nutrients, light and turbulence.Netherlands Journal of Sea Research.21(2):113–123.
& y) i4 ^) k4 p$ F. j4.S. Wagener, C. F. Bardele, N. Pfennig,1990.Functional integration of Methanobacterium formicicum into the anaerobic ciliate Trimyema compressum.Archives of Microbiology.153(5):496-501.
3 |% H& a: C' ~5.S. Holler, N. Pfennig,1991.Fermentation products of the anaerobic ciliate Trimyema compressum in monoxenic cultures.Archives of Microbiology.156(4):327-334 .
) V- l+ f3 o" V- I! w6.J. W. Rijstenbil, C. Bakker, R. H. Jackson, A. G. A. Merks, P. R. M. de Visscher,1993.Spatial and temporal variation in community composition and photosynthetic characteristics of phytoplankton in the upper Westerschelde estuary (Belgium, SW Netherlands).Hydrobiologia.269-270(1):263-273." I0 D) Q: W* o
7.Bettina Meyer-Harms, Falk Pollehne,1998.ALLOXANTHIN IN DINOPHYSIS NORVEGICA (DINOPHYSIALES, DINOPHYCEAE) FROM THE BALTIC SEA.Journal of Phycology.34(2):280–285.
9 A9 Y! K$ ]- `, P( u8.Catalina Castell Perez, Suzanne Roy, Maurice Levasseur, Donald M. Anderson,1998.CONTROL OF GERMINATION OF ALEXANDRIUM TAMARENSE (DINOPHYCEAE) CYSTS FROM THE LOWER ST. LAWRENCE ESTUARY (CANADA).Journal of Phycology.34(2):242–249.
3 @1 s0 z0 B7 Q( @# ^9.Teresa Cruz and Jorge Araújo,1999.Reproductive Patterns of Pollicipes pollicipes (Cirripedia: Scalpellomorpha) on the Southwestern Coast of Portugal.Journal of Crustacean Biology.19(2):260-267.
$ Y& S; L. i4 P, `10.Michael Hust, Wolfgang E Krumbein, Erhard Rhiel,1999.An immunochemical in situ approach to detect adaptation processes in the photosynthetic apparatus of diatoms of the Wadden Sea sediment surface layers.Journal of Microbiological Methods.38(1–2):69–80.& j! R3 r9 w: [
11.Christine Dupuy, Solange Le Gall, Hans J. Hartmann, Martine Bréret,1999.Retention of ciliates and flagellates by the oyster Crassostrea gigas in French Atlantic coastal ponds: protists as a trophic link between bacterioplankton and benthic suspension-feeders.Marine Ecology Progress Series.177:165-175.9 P1 x8 e6 @1 X+ b1 `3 j
12.A. Tewari, H.V. Joshi, R.H. Trivedi, V.G. Sravankumar, C. Raghunathan, Y. Khambhaty, O.S. Kotiwar, S.K. Mandal,2001.The Effect of Ship Scrapping Industry and its Associated Wastes on the Biomass Production and Biodiversity of Biota in in situ Condition at Alang.Marine Pollution Bulletin.42(6):461–468.
, A& I2 {7 I _/ [8 N+ L/ {# k13.Hera Karayanni, Urania Christaki, France Van Wambeke, Andrew P. Dalby,2004.Evaluation of double formalin—Lugol's fixation in assessing number and biomass of ciliates: an example of estimations at mesoscale in NE Atlantic.Journal of Microbiological Methods.56(3):349–358.! h" a" Z) f `2 p% p5 D* Z
14.EI Ohimain, TOT Imoobe & MO Benka-Coker,2005.The impact of dredging on macrobenthic invertebrates in a tributary of the Warri River, Niger delta.African Journal of Aquatic Science.30(1):49-53.
- z+ p+ U0 F0 X6 b15.Laurent Seuront, Dorothée Vincent, James G. Mitchell,2006.Biologically induced modification of seawater viscosity in the Eastern English Channel during a Phaeocystis globosa spring bloom.Journal of Marine Systems.61(3–4):118–133.
) i3 z( e. m2 H. H" g z5 g16.Wim A.M. Hijnen, Yolanda J. Dullemont, Jack F. Schijven, Anke J. Hanzens-Brouwer, Martine Rosielle, Gertjan Medema,2007.Removal and fate of Cryptosporidium parvum, Clostridium perfringens and small-sized centric diatoms (Stephanodiscus hantzschii) in slow sand filters.Water Research.41(10):2151–2162.
, R% k. T. }2 D17.Géraldine Sarthou, Dorothée Vincent, Urania Christaki, Ingrid Obernosterer, Klaas R. Timmermans, Corina P.D. Brussaard,2008.The fate of biogenic iron during a phytoplankton bloom induced by natural fertilisation: Impact of copepod grazing.Deep Sea Research Part II: Topical Studies in Oceanography.55(5–7):734–751.$ N f9 z0 K9 I$ h# C
18.Damir Viličić, Tamara Djakovac, Zrinka Burić, Sunčica Bosak,2009.Composition and annual cycle of phytoplankton assemblages in the northeastern Adriatic Sea.Botanica Marina.52(4):291–305.' } d$ P) W: C
19.Fedekar F. Madkour, Mohsen M. El-Sherbiny and Maher A. Aamer,2010.Phytoplankton population along certain Egyptian coastal regions of the Red Sea.Egypt J. Aquat. Biol. & Fish..14(2):95-109.
* Z5 i7 X8 S7 B& C5 Q. m20.Mianrun Chena, Bingzhang Chena, Paul Harrisonb, Hongbin Liu,2011.Dynamics of mesozooplankton assemblages in subtropical coastal waters of Hong Kong: A comparative study between a eutrophic estuarine and a mesotrophic coastal site.Continental Shelf Research.31(10):1075–1086.% _; F2 E# H5 A2 E) _0 x
21.Germán A. Kopprio, Gerhard Kattner, Martin Graeve, R. Hugo Freije, Rubén J. Lara,2012.Exceptional lipid storage mode of the copepod Boeckella poopoensis in a pampean salt lake, Argentina.Aquatic Biology.15:275-281.
: \7 a) h; f1 l! f: R22.Dongyan Liu, Yajun Shi, Baoping Di, Qianli Sun, Yujue Wang, Zhijun Dong, Hongbing Shao,2012.The impact of different pollution sources on modern dinoflagellate cysts in Sishili Bay, Yellow Sea, China.Marine Micropaleontology.84–85:1–13.! Y; c; _6 g) d
23.Daniel Remias, Andreas Holzinger, Siegfried Aigner, Cornelius Lütz,2012.Ecophysiology and ultrastructure of Ancylonema nordenskiöldii (Zygnematales, Streptophyta), causing brown ice on glaciers in Svalbard (high arctic).Polar Biology.35(6):899-908.
. W/ q! j0 H# a& y# \24.F.S. Tahami, A.G. Mazlan, H. Negarestan, Sh. Najafpour, W.W.M. Lotfi and G.D. Najafpour,2012.Phytoplankton Combination in the Southern Part of Caspian Sea.World Applied Sciences Journal.16(1): 99-105.$ t) ^; E5 ` ]; g& Q/ s) d* C
25.Amir Abbas Bazyar Lakeh, Werner Kloas Rainer Jung, Ra’anan Ariav, Klaus Knopf,2013.Low frequency ultrasound and UV-C for elimination of pathogens in recirculating aquaculture systems.Ultrasonics Sonochemistry.20(5):1211–1216.
" }, ]' D3 ]/ t- t8 \# R/ ]
" B4 ^2 B/ H2 g: c' H- F3 k0 K7 [$ O9 [: o0 n. E( \ ]
更多关键字: 浮游植物计数框,藻类计数器,浮游植物计数器, Kolkwitz浮游植物计数框,浮游生物计数框
1 B9 l8 N5 e S$ C) t0 J5 ?1 z- c( \% Y% M( g
. {* o% B) B+ q b, b
8 H8 _6 A/ P: n4 k<strong> |
