如何20分钟做出科研报告?
正参考的20分钟科学报告提纲:
' s# g' Y( g% h" r    1. Title/author/affiliation (1 slide)/ X2 P& P: G& o0 I7 D  G
    2. Forecast (1 slide): Give gist of problem attacked and insight found (What is the one idea you want people to leave with? This is the "abstract" of an oral presentation.)
* t: m3 |5 ^* d* v4 [1 J    3. Outline (1 slide): Give talk structure. Some speakers prefer to put this at the bottom of their title slide. (Audiences like predictability.)! i/ p- R2 E& T5 q" k* b
    4. Background# z1 V% P0 O) B
        4-1. Motivation and Problem Statement (1-2 slides):(Why should anyone care? Most researchers overestimate how much the audience knows about the problem they are attacking.)
, g* s* i( w% i* z        4-2. Related Work (0-1 slides): Cover superficially or omit; refer people to your paper.
4 S- M% s: R$ y& V) S: X  j        4-3. Methods (1 slide): Cover quickly in short talks; refer people to your paper.
( o, B0 o/ f2 J+ J' A% B    5. Results (4-6 slides): Present key results and key insights. This is main body of the talk. Its internal structure varies greatly as a function of the researcher's contribution. (Do not superficially cover all results; cover key result well. Do not just present numbers; interpret them to give insights. Do not put up large tables of numbers.)
8 x3 p! }$ v4 Q    6. Summary (1 slide)
4 T6 h$ `. x9 C5 J    7. Future Work (0-1 slides):Optionally give problems this research opens up.2 g. S4 Q8 u6 v6 f% d' T/ g! V
    8. Backup Slides (0-3 slides): Optionally have a few slides ready (not counted in your talk total) to answer expected questions. (Likely question areas: ideas glossed over, shortcomings of methods or results, and future work.)8 P$ i3 c2 L8 i$ E0 N. ]
7 L! r, G6 e" a0 J' ~- B简洁版:
    1. Title/author/affiliation (1 slide)' F( _6 M" q; J
    2. Motivation (1 slide)
. T6 r# `/ `' s9 T: d    3. Background (1 slide)& c; t) ^, N# L* n5 Y' A
    4. Hypothesis (1 slide)
) ^, `9 Q. f; g1 L( ]% x    5. Results (8 slides)6 X* R+ \7 b. W
    6. Conclusion (1 slide); _  y+ D& C( J/ H6 }( N' _) X
    7. Future Work (1 slide)
0 E3 [9 Z) i: q    8. Acknowledgements (1slide)
  |; Y5 g3 b0 [7 ?: W    9. Backup Slides5 }6 U7 L* ]' B$ B
  x8 y+ O1 C$ A1 H+ R6 g& C3 O
举个例子:
: ^2 d+ o$ y, y4 L( r: N
+ v8 q3 j. X7 Q% J(1)原则# O( }: ~9 `6 Z( f5 x- f: U, s
首先,引用 A PhD is not enough 中的话:  z$ v4 h9 Y( `# Q, z) R
As the speaker you are putting on a one-man show. Your listeners are investigating an hour of their valuable time... They expect to hear a good story, with a beginning, a middle and an end...
/ z: f- {2 G( H8 Y. x4 Z( M... Never over-estimate your audience...) [4 V% |; g/ |: K$ _; k6 W2 I# Q' l
是的,要讲一个“故事”,因为大家都喜欢听故事,无厘头在这里就不靠谱了。而且要尽量讲得简单易懂,化繁为简,林老师也说“如果学术报告能够让老妈也能听懂,就是成功”(据说是 Don Forsyth 的名言)。
4 z& V( H5 Q( `
6 e0 p! I2 Y5 c/ g% f(2)结构
  `7 Z- R  f4 J6 z1 G  |我之前分享了一份20分钟科学演讲的提纲:: G7 z0 ?5 u, F3 h' F: v8 p
http://www.joyocean.org/viewthread.php?tid=1789&extra=page%3D1+ o: q, W/ \0 {
以“讲故事”为目标,修改后的最终版本PPT的结构变成了:
0 a2 c1 \' Z5 ]2 k    1. Title/author/affiliation (1 slide)
: l, c& P; {& J' D    2. Motivation (1 slide)* N. B+ K/ `$ A5 P# j, g- N! Z
3 [1 ]5 S( G, z$ }" }8 V    4. Hypothesis (1 slide)6 i0 O( F: k) H: w( c* b4 C0 X2 L) l1 d
    5. Results (8 slides)2 B* f# G& @' w$ r& \$ Z0 \
3 G4 q! j5 U' O2 @! B' I    7. Future Work (1 slide)
* g7 q+ }" X. ?$ h$ F7 R. _' \, }    8. Acknowledgements (1slide)
! `+ l  i' f4 _3 P    9. Backup Slides
2 f% r: [8 x7 l& j7 p  j
8 x- t0 ^* p2 D' K: u几点我觉得比较重要的改变包括:
+ E9 V8 C, m! ta. 删除 Forcast & Outline,这是为了更快的进入“故事”;其实所有与故事无关的都应当删去。( q$ R; I1 K, W6 w: A
b. 缩减 Background,删减后的这个部分只有一张slide,只包括“故事”中必须要用到的概念。- B/ M; |, B1 H9 S
c. 增加 Hypothesis,这个部分有点像文章的 Introduction,与最后的Conclusion对应,介绍这个研究的科学问题。
" `2 z" u& a$ {6 d5 J1 pd. 加大 Results 的份额,这个就不用多说了吧。“讲故事”就在这里。当然了,我发现真正在准备的时候还是很费时的,因为要注意顺序问题,怎样能一张一张有逻辑的将故事说圆了,让大家都没有疑惑。
! V! ~( o( }" L% ]5 W7 L3 q. ~9 j( L6 Y- s+ z
(3)讲故事2 c8 j: i8 ?/ P0 ~" B7 |5 k  `
也就是 Results 部分,也是报告真正的核心内容。与写文章不同的是,因为时间限制,细节问题不需要讨论;这样才能将重要的内容凸显出来。图多字少不用公式也是给短报告的一个原则。
0 W5 V/ ~  Y( Q8 F
' x$ p% P; x. ^3 I9 Y' N(4)风格
8 y7 B* q" b0 n$ \我的第一个版本的每一张 Slide 都包括了进度条和姓名时间,后来在林老师的建议下删掉了。这是因为要“努力使听众集中注意力听故事”。
" {0 _5 O7 N  o# j, |同样,制作 PPT 还有很多细节问题,有些关乎个人风格。目标当然是要显得“Professional”了。下面是林老师在帮我修改 PPT 时的一些建议,在这里与大家分享一下:
$ f+ G" m1 |6 ?: o/ B  [a. 字体: Aria narrow.
0 g* v0 O( P* E1 n" d8 c3 d  g
字体大小: title 32, subtitle 28 etc., not smaller than 18
* T" }4 h. y, o+ ~& T
b.深色底色加上浅色(比如白&黄色)的字5 G. r. J% j1 E
c. 不要过分展示别人的结果,专注于讲自己的故事4 ^; I1 S2 ^1 e5 e& x$ H
$ ]. a. M* w6 h8 ~4 n5 u* D3 Q
(5)画图' l/ o! J4 T8 Z. f" d! A) ^$ J" U
因为图片在报告的重要性,PPT 中的每一张图都要重新画过,推荐用 png 格式。我用 AI 将 pdf 转成 png 格式,同时要注意分辨率,字体大小的问题。下面链接是个很详细的说明:9 |9 }: `! w/ l) y! X7 }  r$ s% a: G  J
www.52ocean.cn2 y+ K% R( I! v; u
8 |9 l3 {4 x1 V* i" G
Ref:www.52ocean.cn
2 Z7 y( b. E* C- H/ v' r! U
( l  S0 |7 f* I/ a3 I9 O7 T9 K2 s  T) a2 l
# B' L2 `0 o6 v9 P0 I7 I) }
oceaner
活跃在2026-1-19
