XZ-0125多参数水质分析仪(带打印机,电池)--吾爱海洋
9 O0 z& C% h8 f ) A% M! Q6 C8 A4 L* @) d
: B# ]  U5 r; A一、XZ-0125型水质多参数测定仪产品概述:
6 S5 P& d; c! K. E: l7 J" ?$ \
) Z& O3 E7 v% e( \( n$ |/ A  XZ-0125型水质多参数测定仪适用于大、中、小型水厂及工矿企业、游泳池疾控中心、生活或工业用水的浓度检测,以便控制水的浊度、色度、余氯、总氯、化合氯、二氧化氯、氨氮、镍、悬浮物、铜、磷酸盐、DPD余氯、溶解氧、亚硝酸盐、铬、铁、锰、色度、TDS、水温,PH、水硬度、COD达到规定的水质标准。5 d% X2 c- s& l/ A/ r% [/ `
  % A5 R  w$ ?2 _9 ^- m& b1 V
  4 S9 w: Q( F7 q6 \* I
  6 r+ l" b4 j, R/ x& d: E/ Q
  二、XZ-0125型水质多参数测定仪原理:  _) P" A3 H% h( n' M& L
  : E' r+ G3 D, g0 x; q7 R. L
  本仪表应用全中文微电脑比例式检测,光电子比色检测离子。消除了人为误差,因此测量分辨率大大提高。8 e6 k7 |* L: c7 |3 [* }1 Y
- V$ ~% D* Z' V# |" ^% b2 d4 s  ) _$ r# P7 p! O- u6 d9 r# }* w
: O, q  ~) e3 ^7 W- K. ^: B  三、XZ-0125型水质多参数测定仪技术参数:
% Q* d9 }6 s; E. E& g3 e% }/ [, J
% l# I/ t$ n4 B+ Q  余氯、化合氯:0-2.5mg/L,0.01mg/L
2 W, X: s0 A4 t* f2 O& o- e3 F9 S  总氯:0-10mg/L,0.01mg/L
8 Y3 ], w! }: X, k7 i4 f7 t$ M8 v  DPD余氯:0-2.5mg/L,0.01mg/L% {6 j2 I/ U# r$ x& O+ P; g6 z
  DPD总氯:0-2.5mg/L,0.01mg/L
+ d2 s" v! A8 l( a# a! v  低浊度:0-20,0.01NTU
( c3 z7 o0 n2 ]) c8 P* D6 I: _  高浊度:0-1000NTU,0.1NTU
) `6 R  R9 @0 ?  二氧化氯:0-2.0mg/L,0.01mg/L' o5 c+ z4 P0 r% w; D6 ^
  氨氮:0-10mg/L,0.01mg/L2 ?5 ?0 `- z/ s2 X1 L4 }$ J7 V, `& i
  悬浮物:0-100mg/L,0.01mg/L; T& g; e$ A/ _) b; Z" M
  磷酸盐:0-1.0mg/L,0.01mg/L
% B# \0 c. s) |7 X* u1 n  铜:0-2.0mg/L,0.01mg/L
6 A) K' X) W. N4 S$ `9 R* g, r  溶解氧:0-12mg/L,0.01mg/L
% z0 I5 V: R% V  磷酸盐:0-2.0mg/L,0.01mg/L1 P1 ~( Q3 \1 a7 \& w$ k/ N" b
  亚硝酸盐:0-0.3mg/L,0.01mg/L
2 J( E2 {3 v0 B  w0 W+ ]/ e" z2 R  铬:0-0.5mg/L,0.01mg/L  z& G8 H6 f6 ~6 G  Y
  锰:0-0.5mg/L,0.01mg/L5 \4 e" X# x) q; i/ d% V
  铁:0-0.8mg/L,0.01mg/L$ ?* k: H$ d) H8 L5 e# c& ?  v
  镍:0-1.0mg/L,0.01mg/L
1 `& i# k# L- D0 d0 g8 }& T  I" S7 z  色度:0-100PCU,0.01PCU  J! X) v5 a/ j. u7 `: F/ @
  高色度:0-500PCU,0.01PCU
/ T& w$ w/ F. S% W  TDS:0-1000mg/1.5%
) L) {. k! s3 A% F' Z, }9 M0 I# x  7 g9 o0 {  u! S" l
  PH:0-14ph+ l$ b* {3 G& F% u: A
4 C4 F$ S9 U1 u3 R% k/ O  温度:0-100°
) @0 I8 T: j. ~
1 y% n% h) a( U/ O) e& e8 R  COD(滴):0-300mg/L
1 [( Z+ j9 l9 S* T
7 `$ o0 |, ^8 J, Z6 p  水硬度(滴):0.01-0.04mmol/L
! Q* G4 \1 P; j: v' w5 {# Q
9 z8 \' R# Y6 X  }  四、XZ-0125型水质多参数测定仪特点:1 e2 {4 c, b1 C5 C, E5 v* t
  # g6 p" w/ X3 W. B5 r+ s
  * O, ~/ J! N" _& l% D
  1.微电脑,轻触式键盘,全中文菜单,采用背光高亮度LCD显示数值,操作和标定过程全中文提示,使用方便。
* ^, c: O4 z2 i  2.可自动调零和5点自动校正,量程有自动和手动切换,并且有数据非线性处理及数据平滑功能。0 {1 [# T0 S% I4 L
  3.本仪器采用特制高强度长寿命光源,*的恒光源半导体发光器使其光源恒稳定,而且光源寿命长达20年,开机时无需预热,可直接使用。
6 g' M5 [! x; F$ D  4.本仪器还具有选择离子测量功能,其光源自动切换,适用于水中25项常见指标的快速定量测定。
* C0 \* a- t- k' ~& Q; X  5.主机内可选配大功率电池,既可用于实验室也可用于野外现场定量测量,充电2小时可连续使用4小时,即充即用。
7 m, Z3 @/ G, U- V  6.采用矩形光学玻璃比色皿,表面平整光洁,克服了圆管比色皿管壁厚薄不均匀造成每次测量的误差,重复性好,测定时更。8 p+ E6 j* P' }
  7.本仪器融合多项自主设计成果,技术先进,符合国标GB/T5750-2006生活饮用水卫生标准。
" @' g! T- A8 l" `8 T3 C* W  , {$ O( F8 C8 m, C) F
3 k1 M) M! S. H  化学法与电极法的区别:
- Q# O! ^6 i% \1 ~- o  5 b' P" y0 P2 Z' V; q7 x5 r+ X
  电极法:
7 k  Q1 ?. A6 w  p8 w9 I/ O  * i- s+ H. Z* r3 a3 u. M, ?
  1.电极法操作简单,不需要检测试剂,但使用一段时间后需要重新校准。
; \/ {8 X+ y+ F  2.使用寿命短,约一年,有的离子电极在检测介质不同寿命更短。
6 J; H& Z3 O9 l, j* o/ b  3.对于各元素之间的抗干扰较差,检测数据误差较大
1 W- p) n  D$ A& [7 Q9 J- K4 u  4.电极维护比较麻烦,清洗困难,离散性大。4 V' b, M$ M4 }
  5.运输玻璃电极易损坏。& H2 g7 q+ m6 o8 Z( p- r
( R1 V$ S9 K  V" \1 X7 W 化学分析仪器 6 F7 c: [7 F( Y- t6 j6 v0 d
( o2 l; D) j" ^- w! t, N: {1 V
  1.化学分析法是国家实验室所使用的仲裁分析方法,准确度高。' K" g2 q: [1 j, w/ j# `: [
  2.对于各元素之间的干扰可以用化学试剂屏蔽,做到元素之间互不干扰,曲线可进行非线性回归,确保了检测的准确性。+ m2 c/ _$ V  D, g5 `6 I& t9 A
  3.取样过程是深入样品中心和多点采集,更具有准确检测。
5 O9 A0 u- h3 m  4.应用领域广泛,局限性小,可建立标准曲线进行测定,仪器可进行曲线自我检测。
: `1 X$ f( B3 r; c: u) s  5.购买和维护成本低,维护比较简单。
5 g( x- L3 D* V# h3 l# z% q  6.化学法*的缺点就是需要检测试剂(显色剂)。
# ], a: R9 Q3 ]. Y8 o
( e2 }  O' ^) F; p        资料下载链接:立即下载
wqldbdwvbo
活跃在2021-7-26
