- s* `4 b: f+ k) r1 y: U; \
+ A* @- s# E, H+ M9 E+ u' o ( p5 k$ g& F4 L" a
9 q4 D/ H! h# ]4 n0 V, M
上海银泽仪器设备有限公司专业生产XZ-0125型多参数水质测定仪,欢迎广大新老客户,:
1 i7 u0 R7 V+ T3 B / S) \; ?; |, C( w! X
一、XZ-0125型水质多参数测定仪产品概述:
; a8 L, {+ F! R" O1 o8 | * c1 ?6 n; ^: F. g! V: s+ X/ _
XZ-0125型水质多参数测定仪适用于大、中、小型水厂及工矿企业、游泳池疾控中心、生活或工业用水的浓度检测,以便控制水的浊度、色度、余氯、总氯、化合氯、二氧化氯、氨氮、镍、悬浮物、铜、磷酸盐、DPD余氯、溶解氧、亚硝酸盐、铬、铁、锰、色度、TDS、水温,PH、水硬度、COD达到规定的水质标准。
, u8 h0 U0 G$ w0 ~! [ : F* O; C$ k' n- I
\7 a& H: l N# [, h
- C+ {( u: d4 M( e3 \% |
二、XZ-0125型水质多参数测定仪原理:
# q S7 w) F" _; } ! V; a3 x! U$ w7 D6 ^& O, F6 H
本仪表应用全中文微电脑比例式检测,光电子比色检测离子。消除了人为误差,因此测量分辨率大大提高。5 L) X0 L8 O/ W D! ^- }
! B9 i& y: b0 o4 g6 `* _
6 i% l9 \( q3 b) n
9 ^* x/ p9 b+ m# R
三、XZ-0125型水质多参数测定仪技术参数:( P( S* K2 E- Y2 i
4 k" V( G1 r$ b- W* R 余氯、化合氯:0-2.5mg/L,0.01mg/L) h" N7 { S: R
总氯:0-10mg/L,0.01mg/L
7 n' {2 f! u! Z, F( G0 t2 ] DPD余氯:0-2.5mg/L,0.01mg/L
8 Y1 z3 I* e8 n" U h% m DPD总氯:0-2.5mg/L,0.01mg/L/ K" l/ \% h# i8 R& T0 s. l
低浊度:0-20,0.01NTU' b4 `2 B6 K$ d. |" \% y
高浊度:0-1000NTU,0.1NTU5 d2 P) T! A6 T5 l/ v4 B
二氧化氯:0-2.0mg/L,0.01mg/L1 r- l4 q* g9 `' c5 }) h' J
氨氮:0-10mg/L,0.01mg/L
. o8 h; a+ i" h2 f% y. O8 g 悬浮物:0-100mg/L,0.01mg/L
7 t+ M6 o7 }& p, |' ~- c: c0 l 磷酸盐:0-1.0mg/L,0.01mg/L1 n/ d6 L, F8 S' p
铜:0-2.0mg/L,0.01mg/L& E; Y( I3 u) [0 h0 l8 O; F
溶解氧:0-12mg/L,0.01mg/L* x; ~* ], P) r" g2 G# U$ u; u
磷酸盐:0-2.0mg/L,0.01mg/L# y$ e; z) n3 K/ ~ q/ d. @8 v
亚硝酸盐:0-0.3mg/L,0.01mg/L
. W2 C9 {2 ?) X5 @! U. k 铬:0-0.5mg/L,0.01mg/L4 w. C5 K- z" [8 s
锰:0-0.5mg/L,0.01mg/L
. ^2 b* D( I6 v% l! L 铁:0-0.8mg/L,0.01mg/L' X( J2 O/ Z+ ]
镍:0-1.0mg/L,0.01mg/L
: A2 e/ U1 I. v; z8 W 色度:0-100PCU,0.01PCU/ ~ e9 W. G( W$ J$ T* T0 X
高色度:0-500PCU,0.01PCU' m* Y9 u: @- X! s
TDS:0-1000mg/1.5%
, K. U6 n! P) b
" e- ~) o5 I8 \# H# a$ p PH:0-14ph0 @! P2 t+ _; `0 u
" [* Q& q9 E, Z. R# [6 I7 h! ~ 温度:0-100°6 V. v/ d5 ^6 r4 E+ p5 }
2 \3 s! M% t1 r; D' b( o
COD(滴):0-300mg/L( n% d1 _! r: w
, a2 i% s, V0 f2 E
水硬度(滴):0.01-0.04mmol/L; @! @& W0 X9 z% u) @' H, |0 {5 S
7 T# g/ O" ^# v4 f8 m. J
四、XZ-0125型水质多参数测定仪特点:0 H1 n# }$ T9 i) ^& l% T+ b" @
; }8 U. a; w$ y8 g+ o& E( @ 2 X1 z% ~9 d) m7 w0 Q, C8 S
1.微电脑,轻触式键盘,全中文菜单,采用背光高亮度LCD显示数值,操作和标定过程全中文提示,使用方便。
! W m$ S! \' b, H4 K" | 2.可自动调零和5点自动校正,量程有自动和手动切换,并且有数据非线性处理及数据平滑功能。' B E. m- }4 k+ ]/ j" i9 E
3.本仪器采用特制高强度长寿命光源,*的恒光源半导体发光器使其光源恒稳定,而且光源寿命长达20年,开机时无需预热,可直接使用。
( ]2 \+ A7 s. _! d 4.本仪器还具有选择离子测量功能,其光源自动切换,适用于水中25项常见指标的快速定量测定。5 I1 o9 Q( \) _7 U
5.主机内可选配大功率电池,既可用于实验室也可用于野外现场定量测量,充电2小时可连续使用4小时,即充即用。
; ?4 E( [6 `* Y 6.采用矩形光学玻璃比色皿,表面平整光洁,克服了圆管比色皿管壁厚薄不均匀造成每次测量的误差,重复性好,测定时更。
" t7 c9 H7 O3 { 7.本仪器融合多项自主设计成果,技术先进,符合国标GB/T5750-2006生活饮用水卫生标准。
& \; v) K9 y5 D2 R0 E8 _# K ~5 V; y9 o, P" M: Q0 u& A% u
) g' A2 y' W4 P/ d. c% G0 Q9 M 化学法与电极法的区别:
) [7 z# e1 D( O; G, h# Q
) d. y+ t7 ^- N7 ` 电极法:
K/ D$ H$ F9 _8 r
2 C& k7 o: o. K1 ]1 c$ M( d 1.电极法操作简单,不需要检测试剂,但使用一段时间后需要重新校准。
/ t5 r0 |- ~( g- P6 r 2.使用寿命短,约一年,有的离子电极在检测介质不同寿命更短。
. k F" f9 {. p" `4 h( I 3.对于各元素之间的抗干扰较差,检测数据误差较大/ F6 r6 N6 w7 E. P$ F$ S, d
4.电极维护比较麻烦,清洗困难,离散性大。+ |1 Z( q( I* d p$ `& k1 o5 b! j! _3 M
5.运输玻璃电极易损坏。) @3 q+ p; N0 @; k8 {4 M
; p0 l ?" U$ c; I3 i. H5 O5 N
化学分析仪器 $ b* C% l" i: L; ]# {. ]
, _4 D3 f2 f* O$ {* F# q# o4 { 1.化学分析法是国家实验室所使用的仲裁分析方法,准确度高。
, s& L4 u) T1 q% f% S1 K 2.对于各元素之间的干扰可以用化学试剂屏蔽,做到元素之间互不干扰,曲线可进行非线性回归,确保了检测的准确性。
# n5 G9 `/ }$ B 3.取样过程是深入样品中心和多点采集,更具有准确检测。5 _0 S0 M5 l/ [: i1 }
4.应用领域广泛,局限性小,可建立标准曲线进行测定,仪器可进行曲线自我检测。7 k" u3 ~2 c- x3 r- e3 b0 z
5.购买和维护成本低,维护比较简单。& `, S! x8 x O" `
6.化学法*的缺点就是需要检测试剂(显色剂)。
) E3 @- F5 z% t q2 r- g& C7 {' s) U0 \
资料下载链接:立即下载 |
